which bars?
[Closed] which bars?
[#3950439]
after some new bars, at the monent i have some easton ea50 which measure about 670mm wide, also a ea50 stem which is 90mm. they seem to flex alittle and creak, they also seem slightly to far away so im after a 70mm stem and 31.8mm bars.
no idea what bars i should be after, the bike get used for work and local trail centres. i have not had an issue with the rise (apears to be 40mm from centre of clap to top of bars) or the width
thanks
Posted : 07/05/2012 3:31 pm
i have had about 3/4 sets of bars in my time and at the minute the answer pro taper am are the best bar ive rode on yet. 720 mm wide 1" rise.
Posted : 07/05/2012 3:37 pm
There are loads of bars on the market and it's just a case of finding the ones that suit your criteria. When I had new bars I chose based on:
- Width
- Rise
- Price
That left about 3 bars to choose from so I picked the set from the best known manufacturer.
sweep is important too. easton are normally about 9 deg.
Posted : 07/05/2012 3:55 pm
Get some that are 700mm or wider. They are just better for everything, no exceptions.
Posted : 07/05/2012 4:27 pm
andyl - Member
sweep is important
Don't forget Sooty....
Posted : 07/05/2012 4:35 pm
have been recomended answer ones also, been looking at these. wouldnt mind the carbon ones but slightly out of my price range, guessing the only differance is the weight and they are slightly stronger?
http://www.chainreactioncycles.com/Models.aspx?ModelID=42513
Posted : 07/05/2012 8:58 pm
Merlin have alu havens (711) or havocs (750) for £39.95 less 10% ATM.
You could've got haven stems for £45 the other month too but now they are back up to £60-ish I think...
Posted : 07/05/2012 9:25 pm
+1 for havocs you can always get the hacksaw out if you don't like the width.
Posted : 07/05/2012 9:53 pm
havocs seem like a good deal, gives the width to cut if needed
Posted : 12/05/2012 1:54 pm
Fortunateson09 - Member
apart from my local trails and places such as cannock, the trees are too close together
Posted : 12/05/2012 1:57 pm
have Havoc alu's on mine. I like them. I've kept them full width
Posted : 12/05/2012 2:00 pm
Bought some of [url= http://www.wiggle.co.uk/truvativ-hussefelt-riser-black-handlebar/ ]these[/url] this morning. Light ish, wide ish, cheap!
Posted : 12/05/2012 5:01 pm
Daveh: 700, pffah, hardly worth getting out of bed for! 😉
Got my set of havocs through the post the other day. Definitely heavier than the carbon havens, that's for sure!
Posted : 12/05/2012 6:33 pm
I just picked up some alu havocs at merlins, seem to ok at the minute. I bought a RF turbine 60mm stem and can't believe how light and well made it is. I think I've had most of the quality stems but this to me beats them all.
Posted : 12/05/2012 7:08 pm
Had my Easton Havoc's for about 4 months now and they're perfect. Haven't even thought about cutting them down even once. When you get lock on grips on them, 750mm isn't that much after all. Love 'em 😀
Posted : 12/05/2012 7:19 pm
+1 havoc, lovely bars by all accounts and enough usable space to trim a bit of needed.
Edit: I should add that if you're already over stretched and going wider you might want to consider a radically shorter stem. Maybe even 50mm. It'd be ideal if you could borrow one to try first though.
Posted : 12/05/2012 7:23 pm
what about these bars??
http://www.chainreactioncycles.com/Models.aspx?ModelID=72042
Posted : 12/05/2012 8:14 pm
i have been moving the lock on grips out on my current bars, i went to 720mm and they felt better, then 750mm and they felt much more comfortable. i have yet to ride with this yet and im still on a 90mm stem which will get changed to a 70mm. going to get some havocs, if i dont like it in the end you can easily chop a bit off the ends
Posted : 12/05/2012 11:11 pm
I'm selling my Easton carbon EC70 they are 685mm and in mint condition. £65 posted.
Posted : 12/05/2012 11:36 pm
just ordered some low rise black havocs for £35 from merlin, £59 at crc
Posted : 13/05/2012 8:29 pm
