Where can I get thi...
[Closed] Where can I get this freehub?
[#3565854]
Hello!
I need to replace my freehub. It has come off an own-branded Commencal hub, from ~2007, and I am sure it is a Formula OEM hub. The holes on the disc-side flange seem to point to Formula. But I can't find anywhere to get a Formula freehub (their website is kack), nor can I find anything on google which looks the exactly the same as mine.
This looks similar: http://www.chainreactioncycles.com/Models.aspx?ModelID=49538
But what is the ring on the second picture? Where does the cassette lockring screw in?
But even this is not 100% identical. There seems to be a larger lip on mine - below the splines at the freehub/hub interface.
Any advice/past experience with a freehub like this (and where to get them) would be brilliant!
Ta.
Posted : 14/01/2012 9:26 pm
Dont know if this is any use to you
http://www.edinburghbicycle.com/ebwPNLqrymode.a4p?f_ProductID=8626&f_FullProductVersion=1&f_SupersetQRY=C282&f_SortOrderID=1&f_bct=c003154c003137c003539
Reduced to £7.49 so may be worth a punt anyway,bear in mind the pic could just be a library photo not actually of the real freehub.
Posted : 14/01/2012 10:14 pm
Maybe. I'll email a picture to EBC, maybe they can confirm what it actually looks like.
Thanks
Posted : 15/01/2012 1:00 am
It may be quite cost effective to just change the whole hub if that proves to be the wrong part.
Posted : 15/01/2012 6:19 am
