Where can I find ch...
[Closed] Where can I find chainrings for my fatty?
[#10395714]
2x10 Raceface Ride cranks with 36/22 chainrings. Can’t seem to find replacements anywhere. (The originals have worn out.)
I want to keep the cranks as they’ve been shortened to 165mm, and have no interest in going 1x10.
Any ideas?
Posted : 18/12/2018 2:28 pm
Looks like standard 4 arm 104/64mm bcd so any chainrings that match that should fit.
Posted : 18/12/2018 2:33 pm
Ta - I can’t seem to find any though!
Posted : 18/12/2018 3:44 pm
Superstar have teh 104bcd rings, round or oval
Posted : 18/12/2018 4:11 pm
Loads of places have these - completely standard rings.
https://www.chainreactioncycles.com/chainrings?f=2258,4294963506
Posted : 18/12/2018 4:40 pm
Absolute black?
SJS cycles is a good place to look for any size of chainring ever made.
Ta - SJS is a good shout. Virtually all the others are narrow/wide as far as I can tell.
Posted : 18/12/2018 5:34 pm
https://www.chainreactioncycles.com/mobile/chainrings?f=2258,4294963506,4294962987&_requestid=1802844
You can filter the CRC ones for doubles, not many in there but its also one any lbs would either have or get for you really easily
Posted : 18/12/2018 5:54 pm
Only one! and I don't think that it would fit because the granny ring bolts to the outer ring, rather than the spider.
I thought I would be falling over these wherever I looked, but have been really surprised how difficult it seems to track down 2X chainrings. I've ordered a couple of Shimano ones from SJS, which I hope will fit.
Thanks all 🙂
Posted : 18/12/2018 6:53 pm
I may have some in the garage from when I went 1x..... I'll look tonight...
Posted : 19/12/2018 9:01 am
I’ll look tonight…
Thanks - I'm hopefully sorted, but if they do turn up...
Posted : 19/12/2018 6:50 pm
Just for the record, the larger Shimano ring doesn’t fit on the Raceface spider - the inner diameter of the lugs is ~2mm too small. Have bodged it on by filling some off the lugs. Hopefully these ones will last more than 1500 miles if I keep a better eye on the chain!
Posted : 22/12/2018 5:03 pm
