whats everyone'...
[Closed] whats everyone's thoughts on drilling frames?
[#6482610]
Soon to be stripping down my older model trance for fresh paint but thought I'd get any work out of the way before paint instead of ruining a fresh job,
Parts I'm looking at modifying are gear cable stops to run full length outer and a hole in the lower seat tube between bb and pivot to allow a giant switch stealth dropper(its a small frame so any cable loops will interfere with rear wheel)
Just to note I am not the original owner so warranty is void anyway
Thanks
Posted : 14/09/2014 12:31 pm
I drilled my Hemlock for a stealth, after having a wee chat with Cy (who basically said "It's not moronic, but don't come crying to me if it breaks"). It's been grand. The actual hole-making was a pain in the arse though because of the angles, you basically need either an oval or an oblique hole and neither was easy to do on my frame.
Posted : 14/09/2014 1:37 pm
Hole coverage wise I can blank it quite easy with a grommet from work in round or oval so slightly larger drill bit should work ok
Posted : 14/09/2014 2:00 pm
I drilled a mudguard mount in the wishbone on my 853 Inbred. Didn't even think about it really, just got the Bosch out! Still no probs 4 years later. 🙂
Posted : 14/09/2014 2:11 pm
