What to look for wh...
[Closed] What to look for when buying used Boxxer RCs
[#5298680]
Afternoon folks. Am going to look at some used Boxxer RCs at the weekend the seller lives locally. Apart from cosmetic condition is there anything I can check properly while the forks aren't attached to a bike?
cheers
Posted : 02/07/2013 3:42 pm
They're pretty straightforward forks tbh. Should feel smooth off the top, not much resistance to a bump. You might want to spin the rebound and make sure you can tell it's making a difference (at full, it should be very slow). Quite hard to check bushings tbh but if they're worn, with boxxers, the fork tends to go a bit stiff/notchy.
Condition's a reasonable indicator tbh, dh forks get used hard so generally will look shagged before they're actually shagged. If they look good, fair chance they are good.
Posted : 02/07/2013 4:27 pm
