Me 60psi.For 175lb rider I think I should be upping the pressure.
Depends very much on the shock and bike, but your bodyweight in psi is usually a good starter for a Fox rear.
I don't what to come across all mean but. Does it not change from one frame design to the next
And from one shock to the next
60psi!!!! How big is the can on your shock? Is it one of those massive foes shocks? I run about 90psi in my forks.
I run about 220psi in my Monarch+ on my Enduro. The accepted rule of thumb for a starting point is 1psi per lb of weight. I am just about on that fully kitted up.
160 or so here, a few percent less than my weight.
On my Orange 5 I used 160psi for about 30% sag (small air can). I'm 12.5 stone, so add some for kitted up. On my new Stumpy I use 180psi for 25%ish (maybe less), but the compression damping is virtually non-existent. When I get it serviced I'll get them to firm up the compression which will mean I can use less pressure.
