What mech for Hope ...
[Closed] What mech for Hope 10-48 cassette
[#9283888]
Was planning on getting a lovely 10-44 cassette on the next bike, but seen the dinner plate 48t meaning I can probably go up a chainring size and still have a getout gear!
Question is though, will the standard SRAM mechs work with such a big range? I've always beena shimano guy but just made the switch). Is it a case of B-screw all the way in or am i going to have problems with a medium cage or dodgy shifting?
Posted : 21/02/2017 4:34 pm
When is the 48T available? Anyone know?
Im guessing even a GX 11 spd mech should be ok...?
Posted : 21/02/2017 4:42 pm
Couple of months I think - but that should tie in nicely with the time I get the frame! Was looking at a GX mech, but wondered if anyone's had any luck with them on the 11sp expanders etc
Posted : 21/02/2017 4:44 pm
There is a review online with the GX mech and the 44T Hope.
Found it via google earlier when you posted this. 😉
Posted : 21/02/2017 6:01 pm
Hope replied to my email saying they are available now direct from them @ £175 and usable with an M8000 mech although i didnt ask if the medium cage was adequate. Still cant wait to go 1x 11 with a big range such as this
Posted : 22/02/2017 3:35 pm
Ah damn - so they're a bit more expensive too... I might just stick with the 10-44 and have the security that I've got with the med-cage mech. Cheers!
Posted : 23/02/2017 2:19 pm
Are more people using the 10-48 now? Are you getting away with the medium cage mechanism or does it need a long one?
Posted : 28/03/2017 2:33 pm
I had a 10-44 cassette and used an XTR medium cage rear mech with no dramas at either end.
It was a bit weird shifting wise in about the 4th cog up from the 10 though. Shifting was never very crisp and it needed a bit more pressure at the shifter to get it to change nicely.
I did spend a long time setting up and tweaking it so dont think it was down to operator error.
Sold it and bought a SRAM X01 10-42 cassette in the end and this has been perfect for the same cost. haven't particulary noticed the loss of the '2' from the low end either.
Posted : 28/03/2017 5:28 pm
10-48 tooth cassette with Shimano M8000 doesn't work well. Likely work better with Sram 11 speed as the guide wheel tracks closer to the cassette.
Posted : 04/10/2017 4:24 pm
