This is the time of year when I like to look at all those Strava stats and see whether anything actually emerges as significant. I've always been interested in climbing and have felt that my FlareMax is a bit slower in that department, but was surprised to find that it seems to be consistently 5-10% slower than my old (2013) 26" Five. More the longer the climb. I'm at a loss to really explain why though. The Five was hardly known as a great climber after all.
I've ruled our weight. The FlareMax is a couple of pound heavier, but that would account for 1% at most and I'm now using a lighter pack than I was on the Five, which probably eliminates any difference in practice.
I don't think it is the tyres. The Nobby Nic/Hans Dampf combo shouldn't be any faster than the RockRazor/Magic Mary on the FlareMax. The MM has a bit more drag than the HD, but the RR should roll better than the NN and the rear is more important than the front when climbing.
I can't see any evidence for a change in fitness. Times on climbs on the road bike for example have improved if anything.
These are mainly natural climbs. Not really technical, but not just fireroad either, so I'd expect the 29er to have an advantage with its better rollover (and shorter travel).
The FlareMax feels more planted than the Five and the front doesn't lift or wander as much I don't think.
The rear on the FlareMax is stiffer than the Five.
Could it be down to kinematics? Could it just be the X-fusion O2 shock absorbing a lot more energy than the Fox factory model on the Five? Neither seems very likely, but I'm not sure where else to look.
Pedal efficiency of the system maybe?
A steeper seat angle makes a difference.
Less power being wasted in the suspension also makes a difference.
Tyre pressures - carcase stiffness.
Your own rollercoaster of dynamic FTP and leg freshness?
Wheel weights?
The reason I picked this particular comparison is that it's the one where I have enough samples to deal with variations in my fitness. I looked at climbs of over 20 minutes (to rule out short bursts of effort compensating for differences) and restricted the analysis to climbs where I'd done at least 5 attempts on each bike. There wasn't a single one where the FlareMax got within 5% of the Five on average.
The Five pre-dates the modern fashion for steep seatposts. It was a "true" 73 degrees. The FlareMax claims to be 73.6 degrees. I've also got the saddle mounted a bit further forwards on the FlareMax so I doubt it is any less steep in practice.
"Pedal efficiency of the system" yes, probably, I'm just not sure which part of the system as I can't see any part where the old Five should have an advantage.
Wheel weight? That did cross my mind. It would make it feel less snappy, which is why I wanted to check the stats to see whether what I felt was actually real. But on a longer sustained climb that should have less of an effect and be compensated for by the better rollover. There aren't many XC racers left on 27.5" after all even though those wheels would be lighter.
The ebike forums are always banging on about shorter chain stays make better climbers
Well at 425mm the Five certainly had much shorter chainstays than the FlareMax (448mm). I thought longer chgainstays were better for climbing though. Keeping the front end down. Mind you road bikes are sub 420mm and they climb OK. I can see that longer might lead to more flex, but nobody ever called the rear of a Five stiff. It's a possibility though.
I wouldn’t rule out tyres. Mary is a pretty draggy thing even on the front. Compound also makes a difference. Rock razor looks fast but what compound is it?
Different gearing may explain it. Newer bikes with dinner plate sprockets encourage you to sit and spin away gently while with older bikes you had to put in more effort to keep spinning.
Group ride vs solo, summer v winter, trails deteriorating....... list goes on.
Even thing like bar position can make a difference. There are loads of small variables.
I found my fastest climb on a short steep road hill was on my hybrid bike, not my light carbon road bike. Basically because it had wide mountain bike handle bars. Nothing to do with gears, frame, modern geometry, expensive components etc.
Drive train losses? Clutch mechs, narrow wide chainrings and a horrible chain line in climbing gears on modern bikes can't help.
I gave up on trying to predict this when I got my Ragley Ti- still the best technical climber I've ever ridden, and a very good nontechnical climber, even though it was considered to be basically a descender. I've done stuff like adding anglesets to one bike which made it climb better, and then doing the same on another that made it worse, even though they were overall a pretty similar shape... And on paper my Remedy should be a better climber than my old Trailfox but it's just adequate... And linkages + modern shocks introduce so much power for change that you can't really predict outcomes.
And that's even before you stick a lump of flesh controlled by a meat computer on top and it feels tired when climbing because it's worrying about whether it locked the house door, or pedals like an absolute beast because the trees smell nice
jamezee
Full MemberDrive train losses? Clutch mechs, narrow wide chainrings and a horrible chain line in climbing gears on modern bikes can’t help.
None of these things will make a difference you can measure. (and chainline's no different than using teh middle ring on an old bike, which was always fine)
I guess tyres would be an easy enough one to check. Compounds are pretty similar. Pacestar/Trailstar vs Speedgrip/Soft
For the rest I think I’ve got enough samples to average them out. It’s not a rigorous statistical analysis, but there are over 50 runs on each bike over a mixture of climbs. I’m pretty confident that the old Five climbed faster than the FlareMax, I’m just not sure why.
I would say that the 26" wheels are faster uphill, you heard it here first.
Rotating weight is everything on climbs. 2lbs difference and some of it in the wheels will hurt!
You can never rule out the fleshy lump on top of course. It is true that the FlareMax feels a lot more stable at really low speeds and maybe that encourages a “take it easy” approach. I don’t think that’s it though, or not all of it. Sometimes I try to give it the beans but it just seems that the more effort I put in the less efficient it becomes.
If you want something really weird though, I’m pretty sure that the best climbing bike I’ve ever had was my 4.8” steel fatbike. It weighed a ton. I think each wheel weighed over 2kg and yet it still hold the PR on lots of climbs and is within a few seconds of my best time on a few others. That was fully rigid though and was pretty much the only bike where I could get out of the saddle without feeling like I was just wasting energy. As @Northwind said though, there is no logic to it. I replaced that with a lighter carbon fatbike running the same wheels and it was slower ! That’s old news though. I did a thread on that one and although I never got to the bottom of it it’s the FlareMax/Five comparison that is doing my head in now.
My mate's a mountain goat & always leaves me for dead (but so does everyone nowadays) his 2013 5 was the best climbing bike he'd ever had. We both had 5's but he had 150mm on the front & mine's 140. He's now on a Bronson C & he says the 5 was just as good a climber. In fact the only thing he reckons is better is the grip he gets on muddy descents but that could be cos he's got 2.3 tyres on & not 2.1 Maxxis Advantages.
Yes, maybe the only conclusion we can really draw from all this is that the old Five wasn’t the bad climber peopled liked to say it was.
Also, nobody seems to care about climbing speed on trail bikes these days so it’s not surprising that modern trail bikes are biased more towards the descents. The FlareMax is a perfectly pleasant place to be on the climbs and is so much more capable than that old Five on the way down. That’s what people want I guess and it is only weirdos like me who care (or even notice) that it’s actually a bit slower on the way up.
I do still wonder if there is anything I could do to get that 5% back though.
Would the CC shock make it climb any better than the X-fusion? I could just whack a load more air in and see if that made any difference.
Would faster tyres (say racing Ralph and nobby nic in speedgrip) actually gain enough to make up for the reduced confidence on the way back down? Only one way to find out I guess, but not while the trails are like they are now.
Depends what you class as a good climbing bike?
My Geometron is pretty slow on fireroad climbs but I can get up steeper and techyer stuff on it than I could on previous bikes.
I love climbing and am pretty fast (60-odd climbing KoMs if that counts for anything) and I’ve been pondering similar anomalies to yours.
I currently ride a Bronson 2 which climbs OK. Previously I had a Yeti SB75 which climbed well. I still can’t match some of the times I set on the Yeti despite gaining fitness this year and losing 6Kg from my already light frame (6’2” tall and 67kg). On the other hand, some climbs I’m relatively effortlessly faster on the Bronson. I think those are the ones where traction is king. The Yeti’s Switch rear suspension may be doing something similar to that on your Five, i.e. becoming less active under power and so providing a better pedal platform on smoother climbs. The VPP on the Bronson should do something similar but it feels noticeably more active which provides great traction but reduces all-out speed.
I’ve recently been experimenting with chunkier tyres on the Bronson and I’ve fitted heavier wheels having destroyed two sets of lighter wheels up here in the Lakes. Although the wheel/tyre combination adds only 800g, apparently a small amount in the overall system weight, my climbing times have bombed and it feels like hard work! On the mile long climb up to Tarn Crag from Miller Bridge on the outskirts of Ambleside, I can’t get within 30 seconds of my time on lighter wheels and tyres and I’m generally over a minute slower. Amazing and difficult to explain from a pure physics perspective!
Had a feeling OP had a similar quandry about two fatbikes, with the lighter Canyon Dude being slower...
What were the conclusions from that comparison and can they carry over to this scenario?
What about your riding position? More upright and arms wider on the newer bike?
Also, are you using the same pedals/shoes on both? My Patriot was always a bad climber but I think it's significantly worse now I have flats on it.
Tyres - weight and compound. You used to be able to get decent XC/AM tyres at around 550-650g. They’re now almost always over 1kg.
Going uphill you’re, especially off-road, having to constantly accelerate that weight as it will quickly lose any momentum.
It sounds as though it might be worth trying some lighter tyres when Spring comes, just to see if it does make a measurable difference. I might try over-inflating the shock as well just to see if I'm losing a lot of energy there or not.
That stiffening under load that the Five used to do could well be it though. I was running a double back in those days (remember those) so in the granny ring the chain was a fair way below the pivot. The FlareMax is 1x and even with a 30T up front it's only just below the pivot. Maybe I just had a load more anti-squat in the granny gear on that old Five.
I never did solve the Dude vs Ice Cream Truck mystery though. There was some discussion about the flex in the steel frame and how that might smooth out the power delivery. It seemed far-fetched, but I never found a better explanation.
I have the same bars on the FlareMax that I used to have on the Five and tried to get them at the same height (allowing for smaller wheels etc). I'm also using the same (flat) shoes and pedals as I used on the Five. I've never really found that clipless gains me much, but I could try popping the spds from the gravel bike on to see if that makes any difference I guess.
i changed one tyre and both wheels on my chameleon and saved 800g. transformed the bike from something 'ok' in to something downright fun. no way would i go back. it was a lot of pounds spent to save pounds but worth every penny.
i know the cotics are popular but doesn't it have it's own gravity well? 😉 maybe that weight that 'doesn't make a difference' actually does? mate of mine who i think i only ever beat on the climb up to the local spot on singlespeeds once (perhaps after injury too IIRC) has one and in his words 'love it, but it's not a climber'
if that solution is too simple i'd just say the same as some of the others. humans are complex engines with many factors at play.
probably the only real way is some bro-science PB style. power meter, fixed distance, same tyres, same pressures.
It was a lighter bike that had a better pedal response.
The other things people have mentioned may be minor factors, but those are the two main ones IMO.
I n r a t s but have you ruled out that you weren't fitter when riding the old bike?
I know you've got a decent sample size, but you sure the weather conditions are comparable? In my experience wind is the biggest factor in otherwise apparently random climbing times, most noticeable on road admittedly.
I'm sure he would have noticed the wind..
Mike Levy just did a vid on efficiency comparisons on ten bikes. Didn't really delve into too much detail about the whys, but interesting anyway.
I think the biggest factor is time, as in you are a 5 year older fart.
Comparing climbing times is interesting though. I'm often amazed. I can do a ride and think. Shit that was slow and then see after I have just done a really fast time.
My conclusion is that your head is the biggest factor of all and what the clock says is totally irrelevant. It's all about how it feels which is far more important
Without a power meter I don’t think the data is of any use - I can’t believe that the Cotic could be 5% less efficient with its bigger wheels, similar seat angle and fairly high anti-squat. The pinkbike efficiency test is an interesting watch!
You’re probably enjoying the climb more and hurrying less. 😉
That was my initial thought but he said he is now fitter than before?
I have definitely gone over the hill at 53 and my times (especially ling climbs) that I did when I was 45 are a distant memory and I can't get close to them even though I have done the same amount of cycling in those 8 years. Being that much older just feels like I have less energy to power uphills.
A longer frame will probably put you in a less efficient climbing position as there's less room for your lungs to open up, and your hips are more bent. Aero and weight distribution doesn't matter on a grinding climb
Thanks for all the comments. I can fully understand the scepticism. When the numbers don't show what you expect you are quite right to question the method. Personally I'm confident that there is a real difference between those particular bikes, but I'm also quite content if you don't believe me. You could be right and I'm certainly over the hill. It could also be something as simple as a faulty shock.
This is definitely part of it. The Cotic is very stable and does encourage me to just take my time. I've also managed to get up climbs that I never managed on the old Five, mainly because I took it easy at the start and still had something left for the tough part. So it's not a bad climber, it's just not a fast one.
That PB video was interesting thanks. I'm not really convinced that a power meter makes the test that much more valid though. What is the variability on these? It only needs to be a couple of percent to invalidate the results.
To be clear, I'm not really criticising the Cotic or trying to make it into a climbing demon. There are lots of trade offs that go into making the ideal bike for each of us. Nor would I want to go back to the old Five. Yes, it was more fun on the climbs, but I broke both arms in separate crashes less than a year apart, which was less fun. Of course you can never blame the bike for a crash, but the extra margin for error on the FlareMax is a huge plus for me as I do most of my riding on my own in fairly remote places and it more than makes up for the slower climbs. I'd still be happier if I could make the climbs a bit easier though 🙂
The difference between Summer and Winter is massive. I did a recent ride trying to replicate a 30km ride that I did on a VERY dry day in Spring.
Within the same time I managed about 10km. Turned back really early. Out for 2 hours both times.
I would say that the 26″ wheels are faster uphill, you heard it here first
Everything offical says 29" is fastest. Yet they are heaviest - doesn't make sense
This. I think 2lb of bike weight, particularly rolling weight, make a bigger difference than 2lb of body weight. Also worth noting a 29er will require more anti squat than a 26 to get the same pedalling response, further increasing the Orange's suspension advantage.
No one has mentioned spoke count yet. I usually find more spokes = less power lost.
I've spent ages looking for answers on this sort of thing. Most recently when it turned out my new lighter and shorter travel XC bike wasn't faster at anything than my trail bike. Thought I must be imagining it at first until I rode them round the block one after the other. Sure enough the trail bike pulled like a Saturn V by comparison.
My fastest lap of Whinlatter North was on a 26" HT SS with 650ish bars.
I've been close but never beat that time.
I could analyze bikes but realistically it's me- 2 kids and life priority shift has led to a less quick version.
How much older are you? 🙂
I just checked my times on a local climb, 4.7m and 1253ft which I've done 22 times (on this route).
Rank Date Time Bike
1 2 Aug 2015 46:23 Cube Stereo
2 10 Oct 2012 47:00 456Ti
3 24 Nov 2019 47:07 Flaremax
4 8 Mar 2013 47:55 456Ti
5 22 Dec 2020 48:17 Flaremax
Looks like it's the rider as my 456Ti weighed about 10lbs less than my Flaremax and while age is an issue, I've always been pretty fit and the 5th fastest was this week.
I climbed my banshee rune v3 faster than my 125mm norco optic to Ben Cleuch. Pretty stumped. Maybe all the food!
Could a slacker head angle be a contributory factor? And possibly an unsuitable fork offset for the slack angle, ie one that does not minimise the flop.
I've found rigid bikes with slack HAs need more concentration on a climb because the steering tends to flop more.
Longer chainstays allow a more front biased weight distribution to keep the wheel on the ground, but often the bike then feels less nimble, so steering correction when flopping becomes an issue.
My Flaremax has a -2 degree headset in, so maybe not.
Thanks for the numbers @intheborders I've seen a few people online praising the climbing of the FlareMax but that's the first set of numbers I've seen to back it up.
At 56 I can't rule out the inexorable march of the grim reaper, but with lockdown I've done more riding this year (time, distance and elevation) than ever and have bagged some PRs on the gravel bike, so it doesn't look as though the fitness is falling off much just yet. Maybe I've lost the ability to grind out 20 minute seated climbs or something although it could just be something in the way I've got the bike set up.
