as above im stripping my bulb down on my heckler (its making a funny noise)and the last time i did it someone mentioned a specific grease (i just used finish line teflon white grease last time) what is that green gunk that bike shops use called?
cheers
I don't know what the green stuff is but I like Silkolene RG2 from the motorbike shop. It's red!
I use Shimano grease - thats bright green...
The Shimano Dura-Ace (used to be called Pro-set Lube) green is fluorescent green, its the best stuff I've found by far.
Second the Silkolene, brilliant grease. Thick, sticky and red. mmmmmmmmm
Any decent multipurpose grease. I use castrol myself. White grease IIRC is not thd right thing for hubs
Any thick old gunk will do.
"Bike specific" greases are a rip-off.
Personally I 'borrow' the odd grease cartridge from work which is Total Multi Complex EP2 if you're bothered. We use it (By the carton-of-24-load) for lubricating the pivot bushes on heavy plant. Luuuverly'n'sticky!
:o)
cheers all..!!
I have access to loads of EP2 etc. at work, but its nowhere near as water resistant as the Shimano grease which has a higher Silicon content.
