What ever happened ...
What ever happened to adjustable travel forks?
I seem to recall a set of DT Swiss XMM 140 forks I had on my first proper full suss. They had 140mm travel but could be stuck down at 110mm for climbing. IIRC they would release automatically if you bounced them hard meaning you couldn’t forget to unlock them for the descents.
I had some and they were lovely forks. Forgot to raise them for a descent, they didn't blow off and then didn't work as well afterwards! Still, they were the plushest pre modern Pike fork I ever had.
As for what happened to adjustable forks? Maybe something to do with us riding less do it all bikes and travel increasing? BITD 130mm bikes were allrounders, used for everything from XC to all mountain. These days 150mm+ is pretty standard where as XC bikes are still 100/120mm.
Have Rockshox made an adjustable version of their modern forks (post game changer Pike)? Before that the majority of people wanted Fox and I guess not enough people were buying TALAS so they stopped making them? Reviews saying the cheaper and lighter Float was the better fork can't have helped.
Posted : 17/01/2024 11:32 am
They were targeted at XC riders who wanted to feel a bit gnar on the downhill bits (me!).
You'd get off, wind yer forks out to max travel - and manually, yes manually kids(!), drop your seatpost - then clench your sphincter for the not really that gnar descent to come! 🙂
Posted : 17/01/2024 11:36 am
Speak for yourself - every descent is maximum gnar for me...not due to terrain, more to do with me being utterly useless at descents!
Posted : 17/01/2024 11:49 am
They became unfashionable?
Posted : 17/01/2024 12:00 pm
I believe there were a few two-step (?) forks still around in the later 2010s, IIRC because the Germans were quite attached to the concept.
But as others have mentioned, mostly not needed due to improved frame geometry (not just fashion).
Posted : 17/01/2024 12:07 pm
I blame all those UK frame manufacturers who came out with '456' type frames.
If you're a tight arse like me and you've bought a frame that was based around a 120mm to 160mm fork then you'd be crazy not to get maximum value for money by buying a fork that didn't go from 120mm to 160mm.
Even if you then spend all your time with the fork at 120mm, you're still getting maximum value for money!
Posted : 17/01/2024 12:13 pm
two-step (?)
Dual Position. They were decent. I had Coil Sektors on my Dialled Prince Albert. 120mm for general riding, 150mm for more intentional DH/uplift/bike park stuff. Single switch: min or max travel, big bounce on the front to lock into the travel you just switched to. Not a huge compromise in performance.
Ha! Exactly as per BruceWee!
Posted : 17/01/2024 12:14 pm
two-step (?)
Thanks for correcting, I was obviously thinking of DJ Pied Piper or Double 99.
Posted : 17/01/2024 12:19 pm
nedrapier and nedrapier reacted
 DT78
This weekend I just dug my old pike 454s out of the loft to rebuild a 4x bike.  They seem to still be in perfect working order.  Just waiting on a few bits and I’ll find out soon enough,
personally I quite liked them.  Possible to do the uturn whilst riding as well with a bit of practise and a flatish bit of track
Posted : 17/01/2024 12:20 pm
Page 2 / 2
