what disc size?
[Closed] what disc size?
[#893535]
hi - have just bought some post mount Revelations. Currently have standard mount Hope Mono M4 caliper(the old gold and black one) with what I thought was 180mm disc but wondering if it is actually 183mm. I know I need an adapter which requires bigger disc (+ 20mm) but does it matter if this is a 200mm or 203mm - Hope seem to do both?
thanks
Posted : 24/09/2009 10:40 am
 momo
iirc either size should fit.
Posted : 24/09/2009 10:41 am
will be OK - at the worst, a little washer under it would do the trick
Posted : 24/09/2009 10:47 am
just in case someone was following this..................
203mm disc doesn't fit the 180mm (#3) caliper with +20mm adapter, but as scaredpants rightly pointed out, a little washer between fork mount and adapter sorts it out fine, moving the caliper out a bit
thanks all
Posted : 29/09/2009 8:56 am
TOP TIP!!, I was just about to do the same upgrade, Hope M4 No.3 (gold one) onto Fox post mount with adaptor & 20mm disc upgrade, thanks for the tip all works sweetly now.
Posted : 29/09/2009 11:01 am
