What bearing "...
[Closed] What bearing "stuff" for a bodger (Hope content)
[#6642104]
Hi
I have a set of Hope hoops and a Hope BB on 2 bikes
One of the BB's needs bearings and the wheels could do with some TLC too
Ive decided its probably worth my while buying the stuff as the cost of tools will possibly approach what my LBS will charge me for the job
Having had a mare with the bearings on a full suss bike back in the day Id like to know if there is a do it all bearing puller anyone can rec please
Fitting the bearings back is probably something I should look up too........
Posted : 18/11/2014 10:41 am
I've not done a hope BB, but the wheels don't need a puller, they just need a hammer and drift and a little care- very simple, as bearings go. I'd assume the BB is the same.
Refitting, you can use big sockets if you have them. If you don't, you are less of a man 😉 The Hope kit might actually make sense if you don't.
Posted : 18/11/2014 11:05 am
Hope BB bearings are an odd size, if you weren't aware.
So don't bother spending loads of time trying to find the £2 bearings, they don't exist. You'll be spending over £10 on them I'm afraid.
Posted : 18/11/2014 11:07 am
the hope kit is a revelation actually. - even if just for the nylon faced tube to rest the hub on.
but the rest of it is just specially made tubes that might as well be sockets
Posted : 18/11/2014 11:08 am
cheap bearings on hope hubs have proven them selves to be shit a few times on my bikes.....
5 years out of the original hope ones..... 6 months out of replacement cheapos , 6 months out of the replacement cheapos for those replacement cheapos - back onto hopes and we are 4 years in on them again.
Posted : 18/11/2014 11:09 am
A 40mm plumbing fitting makes a good freehub seal seating tool 🙂
Posted : 18/11/2014 11:12 am
Hubs you can definitely do with just a normal socket set and hammer and a bit of care. Not had to do either of my BBs yet.
Posted : 18/11/2014 11:13 am
Hope BB tool is cheap, and very easy to use. Costs about the same as a bearing - so if you avoid fitting just one bearing badly because of it, it's paid for itself.
Posted : 18/11/2014 11:23 am
Hope tools are very good but the thing you use to rest the wheel on when driving out the axle can be bodged with a reel of parcel tape...
Posted : 18/11/2014 1:41 pm
To spawn a different bodgery branch out of this:
If you do have the hope freehub seal installing tool, it does a great job of seating 32mm rockshox wiper seals into fork lowers!
Posted : 18/11/2014 1:50 pm
