What 700c rubber fo...
[Closed] What 700c rubber for road/ off road
[#7846825]
Looking for lightweight - up to 400g tire for 50% on and off road.
Fast rolling on road and off road able to cope with hard pack.
Thinking Kenda small block 8 pro, Schwalbe sammy slick.
What else to look at ?
Posted : 24/05/2016 8:18 am
Challenge roubaix or compass barrow or stamped pass, gran Bois Cypres, panaracer passeler pt all good tyres
Posted : 24/05/2016 8:35 am
Open Paves.
Posted : 24/05/2016 8:57 am
 aP
Clement X'PLor USH
Posted : 24/05/2016 9:04 am
Asked this question last week here and after some research on the suggestions I decided to go for Vittoria Cross XN Pro Folding Tyres, really fast on the road and good grip on hardback with the side lugs enough confidence in the turns.
Posted : 24/05/2016 10:03 am
I like those Clements mentioned above.
Posted : 24/05/2016 10:17 am
There was a fair bit of talk about the Panaracer Pasela last week. Not tried them, but they might be what I try next when my Schwalbe Marathons wear out.
Posted : 24/05/2016 11:19 am
If you want cheap, my On-One BSC's are pretty good for £20 an end, the 33mm version sneak into your weight limited too.
Posted : 24/05/2016 11:31 am
Vittoria Cross XN Pro Folding Look ok but how long do they last.
I was thinking more along the lines of racing Ralph's or similar.
Posted : 24/05/2016 12:59 pm
Continental Cyclocross Speed seem pretty good. Cheap, too.
Posted : 24/05/2016 1:14 pm
Yep, looked at them but apparently they puncture easier than a condom. Not sure if that's true but quite a few reviews say so.
Posted : 24/05/2016 1:21 pm
I've heard the same said about Small Block 8's.
FWIW I previously had Small Block 8s and am now using the Contis after a punctureful dalliance with Land Cruisers. I haven't had any punctures yet, in 300 miles, but probably will now I've said that.
Posted : 24/05/2016 1:26 pm
On One Gravel roads are good. First time I've fitted the same tyres twice. Had a set of Challenge Gravel Racers in between and they werent much cop.
Posted : 24/05/2016 1:28 pm
Schwalbe G-One have just got a very good review on [url= http://road.cc/content/review/190493-schwalbe-g-one ]Road.cc[/url]
Posted : 24/05/2016 1:30 pm
No puncture yet with the Contis. Only 100 miles or so, though.
Posted : 24/05/2016 1:31 pm
Spesh Trigger Pro's here. Roll well on both surfaces, and light. Running tubeless with no punctures in over a year.
Posted : 24/05/2016 1:56 pm
Depends on just what sort of off-road it is. But for gravel tracks, most sensible touring tyres would be fine. Just get a wide enough size, maybe about 32mm or 35mm.
I like the Panaracer Pasela PT. Fast enough for roads, and OK for paths etc. And no punctures in a few thousand km.
Posted : 24/05/2016 2:02 pm
G-one or even S-one, depending on terrain.
Posted : 24/05/2016 2:13 pm
A lot of these are weighty. G-one is 500g. Not that it makes much difference.
As fat as you can fit obviously, but:
Road biased, but unexpectedly good on DRY trails; Barlow Pass Extralight 330g
Trail biased, but unexpectedly fast on road; Nano Race 460g.
Both not officially TLR but I've had both up nicely enough on TLR and non TLR rims.
Posted : 24/05/2016 2:35 pm
Vittoria Cross XN Pro Folding Look ok but how long do they lasy
They will try and kill you on wet roads though.
Panaracer Gravel Kings replaced my Croxx XN Pros and so far I haven't been spat off on any wet corners
Posted : 24/05/2016 2:41 pm
40C TCS tubeless WTB Nanos. Brilliant tyres. Have transformed the comfort factor of my Cotic X over the Conty CX Kings they replaced. Also feel a bit less draggy on the road, although that's a bit subjective.
Posted : 24/05/2016 4:38 pm
Challenge Gravel grinder 32mm or 38mm, as fast as a 28 on the road and solid as long as its dry offroad.
Posted : 24/05/2016 6:15 pm
I can +1 both of them, to the point that I actually have a couple of bikes set up with a Pasela on the rear and a Barlow on the front at the moment.
Fine for dryish hardpack off-road a bit of gravel and great on road too.
Posted : 24/05/2016 7:38 pm
I used Halo Courier which were great on hardpack/gravel.
Used a Berlin on back and standard on front. 29c so a good size and not too heavy as the Berlin is VERY puncture resistant.
Posted : 24/05/2016 7:42 pm
I have had 35mm Paselas on my commuter/tourer/gravel bike for the last couple of years, one puncture I think, recommended.
Posted : 24/05/2016 7:52 pm
Quirrell, I've just fitted the vittoria XN pro tyres are they really that bad on wet roads?
Posted : 24/05/2016 7:53 pm
Clement X'plor USH, quoted as 435g.
Posted : 24/05/2016 8:05 pm
I like Schwalbe CX Pro's, lightish and cheap too
Posted : 24/05/2016 8:51 pm
As per normal single track protocol, I've ignored everyone and ordered some Hutchinson Black Mamba CX's.
Apparently very puncture proof, light weight, fast rolling and competent off-road as well as on.
Not a bad price £25 each. I'll see how they go.
Posted : 24/05/2016 9:18 pm
 irvb
Moved up from 28mm to 33.3mm Rivendell Jack Browns - virtually slick, so not for mud, but my favourite tyre for comfort and haven't had a puncture in over 1000 miles.
Bought from Velo Vitality in Brighton, who have a good selection of unusual rubber.
Posted : 24/05/2016 9:39 pm
I made a u-turn, and went down like I was on ice, I then headed home and found the back end twitching all over the place in heavy rain, very odd experience.
Posted : 25/05/2016 12:41 am
I've been using XN Pro's for several years now on my Whyte Saxon.
They've coped well on and off road all year round I get around 1500 miles out of a rear tyre.
I haven't noticed any grip issues and I've ridden in some pretty crap condition the past few winters.
Posted : 25/05/2016 5:23 am
As I've just fitted them I'll give them a go, although they do get great online reviews will run them with a little less psi.
Posted : 25/05/2016 8:48 am
Anyone using the xn pros tubeless? Seem ideal for me, s-one is my next choice but out off stock everywhere.
Posted : 25/05/2016 7:49 pm
Bump in case anyone has tried them tubeless?
Posted : 26/05/2016 1:57 pm
 tang
I run the vittoria XG pro tubeless no problems.
Posted : 26/05/2016 2:04 pm
