Weird pedal movemen...
[Closed] Weird pedal movement - what's going on?
[#8432689]
My left pedal has just developed some play, just not in a way I've seen before. Plastic Nukeproof pedals, less than 6 months use, and they have developed about 5-8mm of play along the axle axis (as shown in photo). No wobble or rotational play though. At a bit of a loss as to what's going on?
Posted : 26/03/2017 8:49 pm
The nut holding the cage onto the axle is probably loose
Posted : 26/03/2017 8:55 pm
Are they Horizons? As above, just tighten them up. One of mine was doing that from new.
Posted : 26/03/2017 9:03 pm
Cheers. Will have another look tomorrow.
Posted : 26/03/2017 9:34 pm
Have you lost the nut out of the end of the pedal?
Posted : 26/03/2017 9:37 pm
Not sure. Will need a closer? look tomorrow. It's possible though as I don't remember seeing one there earlier (unless it's really deeply recessed?).
Posted : 26/03/2017 10:05 pm
I ask because I lost one after a handful of rides too. I bought a couple of spares and I've made sure they're properly done up.
http://www.chainreactioncycles.com/nukeproof-neutron-pedal-alloy-end-caps/rp-prod82082
Posted : 26/03/2017 10:07 pm
Well, it was the retaining nut but I hadn't lost it. Didn't think to check for it as it's not visible - recessed a long way into the pedal body. A quick tighten though and all's right again.
Thanks scotroutes!
Posted : 01/04/2017 11:26 pm
