Warped tyre, will i...
[Closed] Warped tyre, will it "recover" ?
[#4479793]
just put on my winter tyres , mud X tubeless, and the rear is really out of shape (quite comedy riding on them 🙂 ). This will be their 4th winter and have been stored rolled up. My question is what are my options ? do I leave them on in hope there return to the correct shape. Run with a inner tube at high pressure. Leave them off the bike with an over inflated tube inside ? Bin them ? Anyone got a good solution.
thinking about it, it was probably caused by standing and being low on air when last on the bike 😳
Posted : 21/10/2012 8:14 am
hmm, well they should stretch much so id assume unless the internals are rotted and it has come apart you could get it back
Posted : 21/10/2012 8:53 am
First thing i'd check with Bontrager tyres is if it's seated correctly, a bit of soapy water around the bead prior to inflation helps greatly.
had the tyre off to repair a small hole that was preventing me upping the pressure past 40 psi, whacked in 65 psi still a little wobbly but ride-able at least. I guess a few rides it will be back to shape enough to run at "normal" pressures. I was wondering whether it could be caused by 4 yrs build up of stans gunk, theres awful lot of dried latex in there but it's a real PIA to remove.
Posted : 21/10/2012 10:26 am
