Wahoo Tickr straps
[Closed] Wahoo Tickr straps
 PJay
[#11865035]
My Wahoo Tickr strap has failed - one of the studs that connects the strap to the heart rate monitor has corroded and snapped after not a huge amount of use (in my view anyway - it was a £40 unit).
Replacement straps are out of stock at Wahoo, and to be honest I don't feel inclined to hand them anymore cash and have the same thing happen further down the line.
Are there straps from any other manufacturers that work or can someone recommend a more robust HRM (I only need one that streams to my bike computer, not one that stores data locally)?
Posted : 02/05/2021 11:58 am
Can't you just get a new 3rd party strap . I use generic 3 quid eBay straps with my Garmin until the head unit clip gave up after 12 years service.
The spendy bit is the bit you clip on.
Posted : 02/05/2021 12:18 pm
 PJay
Can’t you just get a new 3rd party strap .
It would be great if I could, that's what I'm trying to find out - I don't know if they are a generic piece of kit that would be compatible across a range of manufacturers.
I'll have a look on Ebay.
--- Edit ---
Looking hopeful, thanks 👍
Posted : 02/05/2021 12:22 pm
If you send wahoo customer service a moany email they will send you out a new one. They are rubbish though so just keep it as a back up and get a Garmin pro
Posted : 02/05/2021 2:19 pm
Yup I gave up on them for this very reason. Sh*t design for a "premium" product. The replacement will also fail and the replacement after that. So just skip straight to getting a cheaper one from Decathlon with a hook and loop strap and do away with it altogether.
Posted : 02/05/2021 4:42 pm
Mine broke the same a few weeks ago , so ordered a replacement from AliExpress , only a few quid and works a treat , just make sure the studs are 45mm apart 🙂
https://www.aliexpress.com/item/33009335938.html?spm=a2g0s.9042311.0.0.10a34c4dhU4bK5
Posted : 02/05/2021 7:17 pm
 10
I bought a replacement generic from Amazon. It's been working fine for months. This one. Seems like it's out of stock now though.
Heart rate strap
Posted : 02/05/2021 7:38 pm
I stuck the stud back in with epoxy resin and it’s been ok since. Not a good design though.
Posted : 02/05/2021 9:00 pm
These - work a treat and much better value than the Wahoo one.....
https://www.amazon.co.uk/dp/B07MCXCJTW/ref=cm_sw_r_cp_apa_glt_fabc_DA2401G2CD7XGFW5ZMBB?_encoding=UTF8&psc=1
Posted : 03/05/2021 12:16 am
 tlr
Jeepers, what are you doing with them? Mine is over 3 years old, used at least 4 times a week and pretty much looks like new!
Posted : 03/05/2021 1:06 am
Mine failed and I got one these. Been fine for a year or so.
https://www.ebay.co.uk/itm/133252555934
Posted : 03/05/2021 8:31 pm
 PJay
Teamslug, that's the one I've ordered so hopefully it'll work for me too!
Posted : 03/05/2021 8:32 pm
Those ebay straps are used on my Coolpoo (or whatever it's called!) cheapo HR monitor.
It's actually really comfy as it's very minimalistic.
I take the HR unit off after every Zwift session as otherwise the units connectors oxidise up from the sweat. I use a bit of silicone spray on them too, to keep the sweat off.
So yeah, those straps are fine.👍
Posted : 03/05/2021 9:18 pm
The Tickr straps are split and do up at the front like a (confusing) front loader bra. The generic straps aren't split there. Do the Tickr HRM pods clip in OK to these?
Posted : 04/05/2021 9:12 am
+1 on contact Wahoo support, they are excellent IME.
My year old Tickr is doing OK, gets used twice a week, and I'm a sweaty bugger. Seems their kit can be a bit hit and miss.
Posted : 04/05/2021 9:58 am
