Up'n'down...
[Closed] Up'n'downy seatpost woes...
[#2788915]
I recently purchased a remotely operated seatpost for a new frame. As soon as I fitted it I noticed a small amount of vertical play in the travel. When weighting and unweighting the post whilst riding I could hear and feel a knock as it moved up and down by around 1mm. On the 2nd ride it developed 2" of suspension movenent at the top of its travel.
I returned it to the shop who replaced it.
The replacement has exactly the same knock straight out of the box. I have contacted the shop who have tried to reassure me that it may be a "bedding in" issue and to give it a couple of weeks. I'm not so sure...
Could the 31.6mm posts be a faulty batch underfilled with oil? I have a 30.9mm that has been faultless.
Posted : 25/05/2011 5:03 pm
I have a similar, err, characteristic with a Joplin. It is 'fixable' though. No idea if you're experiencing the same thing...
With mine, if it's low, which it often is at the end of a ride, and I pull it out of the garage by the saddle for the next ride the post lifts. Doing this appears to let air into the oil so the saddle will move a couple of inches in a suspension seat post kind of way. To 'fix it' I just lower and raise in the normal way. Job done.
Posted : 25/05/2011 5:22 pm
