Tubless Sealant... ...
[Closed] Tubless Sealant... Liquid Latex?
[#942367]
How effective is liquid latex as a tubeless sealant compared to Stans etc? I have three sets of tubeless tyres and Looking for a cheaper alternative to the branded stuff.
Do you have to dilute the mould making stuff, the 60% solids?
e.g.
http://cgi.ebay.co.uk/Rubber-Liquid-Latex-1-Litre-for-Mould-Mold-FX_W0QQitemZ390097703799QQ
Cheers.
Posted : 11/10/2009 7:34 pm
Just buy Stans, why scrimp on the essentials?
[i]Post closed[/i]
Posted : 11/10/2009 7:40 pm
1 part Latex
1 part Slime
1 part cheap antifreeze
2 parts water
Personally - I can't be bothered, latex on it's own will dry out too quickly
Posted : 11/10/2009 7:47 pm
 gee
Just buy Stans - it doesn't dry out unlike the JRA stuff which leaves goop all over your tyres.
GB
Posted : 11/10/2009 8:09 pm
Uplink's repicy is pretty much what I've used for the last six years with consistently good results. All of the components I bought back then I'm still using, except for the Slime, which is on it's second bottle. I use a tablespoon of each component, with a 1/4 cup of water. That recipe came from here six years ago, and I've stuck with it.
Posted : 12/10/2009 12:04 am
If you use CO2 cartridges to inflate your tyres with Stans, once the bead is popped on, deflate and reinflate using a pump as the CO2 can cause the Stans to dry out and ball up after time.
Posted : 12/10/2009 7:30 am
Is it the CO2 (acid) or the cold from the initial inflation/expansion that's the problem? Better to inflate empty with some soap on the bead and add the latex through the valve when it's seated?
Posted : 29/10/2009 12:25 am
 Smee
CO2 acid - are you sure? I'm a few beers in, but i can see a flaw in that science. 😉
Posted : 29/10/2009 12:30 am
