tubeless woes - wha...
[Closed] tubeless woes - what did i do wrong? - Part 2
[#694112]
the tyre that did not explode last night
this tyre was only inflated to 40 - 45lbs as suggested from last nights thread
thismorning it was nearly flat and when i got home from work it was completely flat
i put some stans tyre liquid in (via the valve - not by taking the tyre off) re fitted the valve core and reinflated to 40 - 45lbs
i then "span" the wheel while it was on the bike
everything seemed good
i started another job and then "bang" the tyre exploded!
what in gods name am i doing wrong?
Posted : 08/07/2009 5:22 pm
oh! it exploded? or banged impressively with a bang off the rim?
you sure you know how much you inflated??
could be the tube God angry...
Posted : 08/07/2009 5:32 pm
 JxL
hmm, not experienced a tyre explosion (run mine at 38ps), but did have problems getting the air not to leak.
In fact it took me over 5 days of the "shaking around the wheel while rotating", then leaving it horizontally. Now its been two weeks and air is not escaping anymore.
Posted : 08/07/2009 5:33 pm
when i say "exploded" i mean banged impressively with a bang off the rim
however, the tyre will nor seal at all and won't take any air or inflate at all
Posted : 08/07/2009 5:43 pm
It a shite system, put a tube in, it'll go up first time, and it won't leak...
HTH
Posted : 08/07/2009 5:48 pm
Are you using proper UST tyres and UST rims?
Posted : 08/07/2009 6:09 pm
yes ust tyres (Schwalbe Racing Ralph Tubeless) on bontrager tubeless (i have been running other tubeless tyres on these rims for 18 months) racelite rims
Posted : 08/07/2009 6:14 pm
