Tubeless with OEM S...
[Closed] Tubeless with OEM Schwalbe tyres?
[#9682418]
Thinking of attempting to tubeless convert the stock Schwalbe Nics on my Trance 2. I know 'tubeless ready' tyres would be ideal but any reason they won't work with some sealant and a decent kit?! Rims are Giant tubeless ready.
ta!
Posted : 22/11/2017 9:59 pm
Yep, will be fine! For best results make sure you get the sealant to plug up the sidewalls 🙂
Posted : 22/11/2017 10:14 pm
From 3.40 it shows you how to plug up the sidewalls
Posted : 22/11/2017 10:16 pm
Cheers, what should I be looking for rim strip wise?
This?
http://www.chainreactioncycles.com/mobile/joe-s-no-flats-tubeless-ready-kit-super-sealant/rp-prod161211
Posted : 22/11/2017 10:30 pm
Yep, that'd work! 🙂
Posted : 22/11/2017 11:17 pm
It also has the valves and the sealant that you need which is good
Posted : 22/11/2017 11:41 pm
Last question!! Rims are Giant 23mm but the kit above is 21mm or 25mm... best to go 25 right?
Posted : 23/11/2017 10:11 am
Tough choice, with wider tape you will get in in the bead which can make fitting the tyre tricky.
That said, I find giant tubeless rims to be a bit crap so it might actually help with sealing a bit. You won’t know until you try.
That said, I think that performance schwalbe tyres with giant rims is a tricky combo to work with.
Posted : 23/11/2017 10:15 am
Is that 23mm internal or external width?
Posted : 23/11/2017 10:24 am
ETRTO 23 so internal I'm pretty sure!
Posted : 23/11/2017 10:27 am
Hmmm, looks like it's the external width, so the internal will be about 19ish. I would go for 21! 🙂
Posted : 23/11/2017 10:45 am
Ok, this Sheldon Brown article claims that the ETRTO figure is for internal width, so you'd be wanting 25mm..
https://www.sheldonbrown.com/tire-sizing.html#iso
Posted : 23/11/2017 11:26 am
Yep the diagram ^^ is for tyres, which measure outside width, whereas rims measure internal width... typically confusing for the bike industry!! Thanks all.
Posted : 23/11/2017 11:33 am
