tubeless stupid?
[Closed] tubeless stupid?
[#5186762]
Trying to sort my tyre issue on the cheap.
would it be stupid to run tubeless on the front and a tube on the back. I can't afford new tyres 🙁 and none of my rear tyres work tubeless.
Posted : 24/05/2013 6:16 pm
Not stupid at all in my opinion, I too have done the same.
Posted : 24/05/2013 6:20 pm
 Haze
Stupid to leave a bike sat in the garage for the sake of sticking a tube in...
Posted : 24/05/2013 6:57 pm
I have two Used Maxis advantage tubeless ready you can have for nothing but you have to pay for postage and packing? they both have a enough tread on to keep you going for a while.
They are around 3 years old now and have replaced due to finding a couple of small blebs on the front tyre after i had replaced the latex in them and was told that it had reacted with the inner casing because of there age, i ran this tyre for a month or so after i found the blebs and had no issues and replaced once i had the spare cash, totally understand if you want to pass.
Up to you??!!
Posted : 24/05/2013 7:07 pm
thanks bones appreciate the offer. I'll think i'll just stick a tube in the rears. need to be 29 anyway. 😀
Posted : 26/05/2013 5:26 pm
I also have a Bontrager jones xc in 29'' if you wanted that for a tenner plus postage? loads of tread and can be run tubeless if required
Posted : 27/05/2013 7:53 pm
Build your rim up with electrical tape of gaffer tape cut in half lengthways and it will work tubeless with whatever tyres you already have. Do a dry run before putting sealant in, just to make sure they'll "bite" on inflation. Redo it with sealant and do the shakeround thing.
Job done.
Posted : 27/05/2013 7:59 pm
