trying to remove po...
[Closed] trying to remove poxy crank....
[#893396]
i've done it before no probs...
slx crank with the bolts on the opposite side to the arm. loosen bolts. jangle it about. nowt happens. why not?
how do i get the bastid cranks out?
cheers.
Posted : 24/09/2009 10:16 am
Have you remover the preload bolt? There is also a small clip that gose between the two pinch bolts that pushes into a small eye on the axle you need to pop that out too not totally remove it as it hinges on one of the pinch bolts.
Posted : 24/09/2009 10:24 am
If it's like XT/Saint:
you've taken the end cap off ?
you've lifted up the little clippy thing thst sits in the slot where the bolts clamp up ?
Well then MTFU and get it off
[edit: Andy M - curse you & your quick typing 👿 ]
Posted : 24/09/2009 10:26 am
as scaredy says remove black cap and fully undo one of the bolts to releas elock pin thingy and (once you have removed the non drive arm) you may need to tap it to get it out
Posted : 24/09/2009 10:30 am
yay.... brute force!
Posted : 24/09/2009 11:30 am
Put it all back together with grease on the splines and the threads of the bolts, it wont fight back so hard next time.
Posted : 24/09/2009 11:46 am
 Tim
Youi dont need to use brute force, just completely remove the bolts, any washers and the rubber thingy and it will slide off
Posted : 24/09/2009 12:22 pm
it was all removed. hasn't been touched in a while. accumulation of sticky crap holding it there.
happy ending.
Posted : 24/09/2009 12:24 pm
