Trying to keep knee...
[Closed] Trying to keep knee warmers up.......
[#1132810]
i got myself a pair of [url= http://www.wiggle.co.uk/p/cycle/7/Gore_Thermo_III_Kneewarmers/5360044644/ ]these[/url] - Gore Knee warmers. I only cycle 4 miles to work and dont want the hassle of putting on full length tights and only need to keep my knees warm.
However for the life of me i cant seem to keep them up. After cycling for 2-3miles they start slipping down the thigh. They are tight and i wouldnt want to go a size smaller as i couldnt get them on.
Any ideas or tricks?
Posted : 15/12/2009 7:39 pm
Do you wear lycra shorts over the top? I find they are the only way to keep leg warmers up.
Posted : 15/12/2009 7:44 pm
no i dont wear lycra over them. i just wear my normal baggies that have a liner.
Posted : 15/12/2009 7:55 pm
 StuE
Suspender belt [img] [/img]
Posted : 15/12/2009 8:05 pm
Shave a line around your leg at the height you wear them, gives better adhesion.
In seriousness, do you use a shower gel/soap that has moisturising properties, as these can stop the sticky bit at the top and bottom of knee/leg warmers gripping?
Have you washed them yet, if so, did you use fabric softener? Again, that stops them sticking?
Posted : 15/12/2009 8:09 pm
ourmaninthenorth -
+1
Posted : 15/12/2009 8:23 pm
I wear my knee warmers over the top of my lycra shorts and have never had this problem
Posted : 15/12/2009 8:50 pm
longer than usual braces ...
or possibly adding velcro tabs
Posted : 15/12/2009 8:52 pm
Do you have them high enough to start with? I've seen people with them too low and not with the seam at the back of the knee before.
Posted : 15/12/2009 9:13 pm
Buy the right size? Get more manly thighs? Mine have never fallen down (Endura ones) with shorts over the top of them.
Posted : 15/12/2009 9:26 pm
lycra shorts over the top works for me.
most of the time any way.
desperately embarrassing if it doesn't.
Posted : 15/12/2009 9:48 pm
There is a glue called "stays-up" which I used to use when compression hosiery to people with less than ideally shaped legs.
I think some top totty uses it to hold those silly plunge line dresses oveer their booblies and to stop fall out. Sadly I never got to supply to them.
It works a treat, but may be a step too far. It is water soluble(with soap i think) and is a simple roll on.
Tinternet has it.
The leg shave should work too. Or you could put them on upside down.
Good luck
Dave
Posted : 15/12/2009 10:48 pm
tie a bit of string around them at the top and fold them over it to cover it....... or cycle faster and harder than ever before for 1 month, watch those thighs grow like Chris Hoys and bob's your uncle
Posted : 16/12/2009 12:15 am
 Smee
Or simply mtfu.
Posted : 16/12/2009 12:27 am
tuck them under your shorts, usually does the trick and i have sparrows legs.
Posted : 16/12/2009 4:09 am
they may be knee warmers, but the top half of it should be right up around the thigh - almost into the crotch - so that the stretch has effect and holds them in place as it try to compress again and grips the leg.
when in lycra, lycra goes over top; when in baggies, warmer goes over the inner short.
But really, I reckon you need to get them up higher; also wash them reasonably often as I find they revert to original shape (not slightly stretched) when you do this which helps too.
Posted : 16/12/2009 4:13 am
