Typed out a longer post but the forum lost it.... anyone comment on how long the inseam is?
Mine, size 30, are 33”/84cm inseam. Measured just now from crotch to ankle. Possibly not much help to you if you take a larger size.
That's helpful, thanks. Can compare them to another pair of trousers I have
How do you like them generally?
Work well for me, fit nicely with no sliding down and the crotch doesn’t snag the saddle at inopportune moments. Not used them a massive amount but still waterproof and clean legs when I whip them off in the garage.
But if you are looking for waterproof trousers I saw these on sale and others have recommended them
https://royalracing.com/collections/sale/products/storm-pants
Cheers but have also seen the Resists for £80 and the length sounds good so think I'll try them
I’ve had the TLD pants fir a couple of winters and just had to had the seat seam restitched. They are a nice fit and comfortable to wear but not that impressed by the waterproofing. Next time I buy I’ll try the royal storm pants
If you do buy size down. The waist is bigger than my other TLD shorts
I’m a 32 normally but 32 in these are a bit too big and can pull down when they get wet
Cheers. I'm usually a 36 or 34 depending on fit so went for the 34. Not too bothered by ultimate waterproofing, was after more of a winter all rounder and as it sounds like the Royals might come up a bit short in the leg the Troy Lee seemed to fit the bill better
