Triple to Double Ch...
[Closed] Triple to Double Chainset - What's Involved?
[#8245331]
I'm thnking of going from a triple to a double chainset. Other than a new chainset and shifter, is there anything else invovled?
Posted : 27/12/2016 1:59 pm
Check frame clearance (chain stay) for the double you are considering - should be Ok.
You missed out the front mech
Posted : 27/12/2016 2:01 pm
 JoeG
You may need to shorten the chain as well. Depends on the size of the new big ring compared to the old.
Posted : 27/12/2016 2:13 pm
Whenever I've done this on a mtb I've kept the shifter and derailleur, can't see why you can't do the same on a road bike! 🙂
Posted : 27/12/2016 2:20 pm
If you tighten the end adjustment screws on the derailleur then it'll resist going into the third, now redundant, chainring
Posted : 27/12/2016 2:21 pm
Cheers to all. I may just take the plunge and overhaul the drivetrain.
Posted : 27/12/2016 2:23 pm
