triple shot upgrade
[Closed] triple shot upgrade
[#3336518]
Anyone know a way to upgrade a cateye triple-shot to the latest gen LEDs?
Posted : 09/11/2011 11:10 pm
I bet trout can. From what I remember of looking at one it looks fairly straightforward - you can take the front off to get access to the leds and they are mounted on star pcbs screwed down to the body which you can get new leds that are the same size - the difficult bit is going to be desoldering and resoldering the connections I guess. Might need new optics - you would need to see.
Posted : 09/11/2011 11:19 pm
Hmmm. thanks! The soldering bit is not a issue....more like how do i know that whatt i'm buying is better and won't kill my battery life....questions questions....
Posted : 09/11/2011 11:23 pm
What year is the unit? You should be able to find what LEDs are in it from the year. Originally they were luxeons at 120 lumen an led -modern ones can be 300+
If you don't alter the electronics battery life will be the same as the leds will pull the same current - you will just get more light from the more modern leds
[i]I think[/i] xpe are a direct swap and xpg might need new optics
try candlepower forums
Posted : 09/11/2011 11:31 pm
THANK. YOU. ! Good idea
Posted : 09/11/2011 11:33 pm
Let me know how you get on, i have been thinking this for some time as the unit and battery are all a really good solid unit but just lack in candles
Posted : 10/11/2011 9:50 am
 Del
i think i'm right in saying that the more modern LEDs require a higher forward voltage than those likely fitted to your cateye so just swapping out the LEDs is not very likely to be the way forward.
have a look at trout's post wrt upgrading the hope vision 2 unit. that will give you a good idea of what's involved, and from that, whether or not it's something you fancy taking on yourself.
trout/smudge and a few others offer very sound advice.
Posted : 10/11/2011 10:33 am
My understanding is the xpe / xpg takes a similar forward voltage to the luxeons and older crees. the xml / mce / p7 is different
Posted : 10/11/2011 10:43 am
I'm might try this with a set of DoubleShots
edit that looks quite old now 🙁
http://www.candlepowerforums.com/vb/showthread.php?163278-Cateye-Double-SHot-mod-Lux-3-to-SSC-P4-(with-Pics)
This looks like it could help you.
http://forums.mtbr.com/lights-diy-do-yourself/1800-lumen-cateye-tripleshot-608544.html
Posted : 10/11/2011 11:08 am
