Building up a singlespeed using an old mech as the tensioner, then I thought I might as well add a couple more cogs..
That seemed to work quite well... so I thought it would be nice to be able to change those 3 gears...
Seems to work well - all the way forward on the fork lockout is 21:39,all the way back is 11:39 and is 16:39 is somewhere in the middle.
This is something I've thought about for a long time. Bit like an old Sturmey Archer but durable. Gears for up, down and along.
Why do people do this?
Good to see a well stocked garage 🙂
I mean singlespeed or normal gears, Shirley?
because:
Weight increase is neglible due to the super lightweight shifter.
And don't call me Shirley.
Or just use a triple crank and SS hub?
I did think about that as well, although you would still need a tensioning device at the back which would add weight.
This was just from stuff in the spares box.
I'm with Al, if you have a mech, why not have more gears? The weight argument is there but it's not a very strong one. I only have 6 gears at times but that's a Hope SS hub so there's a reason for it. Until the hub bursts into flames I guess..
But I'm impressed by the use of the remote lever to shift gears, that in itself deserves a Useful Bodge Award. And I guess it lets you keep the chain tension / mech position tight.
On a similar line, I borrowed a surly tensioner with the adjustable jockey wheel position to try a 3-spd manual shift. Daft, but the idea was to have a SS-ish remote touring bike with a choice of ratios. The tensioner adjustment should allow the chainline offset to work with less risk of dropped chains. Decided that a thumbie and mech with 3 more cogs was weight I could live with ...
I like that, wondered about doing something similar for my town bike using a thumb shifter on friction as its flat all the way to town other than one massive hill I have to walk up, would make carrying the shopping back a bit easier too
Shirley, you need a 32 or 34 to give you a mire useable range off road? You could also then get the ring on the inside of the spider for (possibly) a better chainline?
Like the idea though - I've done the triple ring, single cog before and it worked a treat...
Yeah, the 39T unramped chainrings were £7 on CRC, I would have preferred a 36T.
I may have to change the cogs (11 - 18 - 24 maybe) on the back to suit my riding when I've tried it off road.
Chainline seems ok due to the cogs being shifted to the end.
Wouldn't a tringle speed have 3 cogs at the back and 3 at the front that all use the same length chain like a dinglespeed? What you have there is just a bike with 3 gears!
if you're doing all that you might as well add 5/6 more...
True, I suppose it is just a bike with 3 gears
You save say a hundred grams?
Got to admire someone who can look at something perfectly functional, like a geared bike and thinks to themselves "how can I make a totally shit version of that"
And then they go and do it.
Mud X's mmmmm like em!!
lol, yep pretty much. I'd be pretty miffed if I started out with a geared bike too!
XT cassette = 300g, 3 small cogs = 50g? (250g saving)
XT 9spd Shifter = 125g, fork lockout = 25g? (100g saving)
350g saving being optimistic? 300g saving being Cynical?
75g penalty over pure SS?
What car does the front wing fit?
Audi A6 C5 - It's for sale if you want it...
All the cynics above should get a job with the UCI!
;o)
