trek bb95
[Closed] trek bb95
[#7696636]
hello,
i have remedy 9.9 full crbon frame , year 2013 and neeb bb bearings so i can use my raceface x-type crankset ( 24 mm spindle ). I need to know if I should use oversized bearings or standard bearings as I dont want to damage the frame. Asking as for now I used some standard bearings. they are not loose , but i was able to press them with very little force so was wondering about the oversized ..
Posted : 09/03/2016 9:53 am
You'll need a Trek Madone BB Kit if you don't already have the seals and tube. The bearings should be a light press fit.
Posted : 09/03/2016 2:00 pm
I used a set of Hope BB bearings on my Madone as they were identical in size to the Trek bearing but with a bit better sealing.
http://www.chainreactioncycles.com/hope-bottom-bracket-stainless-steel-bearing/rp-prod36419
You can also use the ceramic hybrid bearing as well.
Posted : 09/03/2016 2:06 pm
if the bearings press in by hand then you should really get the oversize bearings from Enduro. if you need to give them a little light assistance, then they're fine and any 6805 bearing would do the job with a top hat spacer.
Posted : 09/03/2016 4:07 pm
I have just replaced my ones
got the bearing form -
http://www.wychbearings.co.uk/bike_bearings.html
using the part numbers off of the old ones and fitted using Loctite bearing fit.
Posted : 09/03/2016 4:19 pm
I thought the 6805 was a 25mm inside diameter, do you not need a 24mm ID for a Shimano axle?
Posted : 10/03/2016 12:52 am
guys I need to know how to correctly install my raceface atlas crankset. should I follow the shimano diagram setup as provided by Trek ?
If I understand it correctly I should not use the black 2.5mm metal spacer and the wavy washer unless I have GXP cranks, correct?
And when tightening my xtype cranks , shoul I watch the preload or just tighten the 8mm hex as hard as it will allow? I dont want to wreck new bearings..
Posted : 10/03/2016 9:15 pm
Not sure if it will help you but my race face next on a Trek Top Fuel is torqued to 50nm on the 8mm hex bolt - no wavy washers fitted, just the seals.
Posted : 10/03/2016 10:32 pm
Yes, you need to use a top hat spacer, raceface one will fit from crc.
[url= http://www.chainreactioncycles.com/mobile/race-face-x-type-bearing-cap/rp-prod39505 ]http://www.chainreactioncycles.com/mobile/race-face-x-type-bearing-cap/rp-prod39505[/url]
Posted : 20/03/2016 7:28 pm
