the top one is for swan neck tow bars. if you have a standard Type Approved towbar then you need the bottom one. the pendle racks are not interchangeable between the two. we have a swan neck, the braqcket sticks out a fair way but woe betide any tail gaters!
detachable ones tend to be the swan neck type which means you'll be stuck witht he first.
they're fine.
only issue might be that you can't tow a trailer at the same time as carrying bikes.
You might find [url= http://www.singletrackworld.com/forum/topic/tell-me-about-tow-bar-mounted-carriers-for-bikes ]this thread[/url] useful.
Hi
I use the top mounting block on 2 cars one with swan neck and other with flange type towball. Works great with either.
Thanks guys, just found out Witter have started making a swan neck with a flange type fixing on the end.
