Tire pressure measu...
[Closed] Tire pressure measurement
[#899292]
How do I measure tire pressure with Presta valves?
Current guage is built for Shrader and the adaptor I use with my pump does not allow pressure measurement - is there a bespoke guage?
Posted : 26/09/2009 10:40 am
I've got the oxford one from CRC that does both. However, before that, I used an adaptor and a cheap halfords press on type digital guage.
Makes a difference when you start using one. I didn't realise just how firm lower pressures felt. Quite often the 40 psi minimum on some tyres is way way too much.
Posted : 26/09/2009 10:44 am
Must be the style of adaptor I have; sort of a hollow tube that relies on greater pressure at pump end to push the pin in
Posted : 26/09/2009 10:56 am
have you screwed it on far enough? If you do, the presta pin should protrude enough to act like the core of a schrader valve. Does your pressure guage have a pin or cross within the push the pin?
Posted : 26/09/2009 11:01 am
Track pump with gauge is accurate enough
Posted : 26/09/2009 11:05 am
The adaptor has a very positive 'end' to how far it will screw on, the pin is then about 4mm below the top of the adaptor. Guage has a round pin to pish onto valve, but nowhere near long enough to reach
Posted : 26/09/2009 11:06 am
I use a track pump or a compressor with a schrader head or a presta head. The presta head is spot on but the other two are not. Besides, I've found that with some tyre, 5 psi can make all the difference.
Posted : 26/09/2009 11:07 am
You could try filing a few mm off the adaptor so the guage plunger reaches deeper in, but it's probably easier to get a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=8504 ]presta compatible guage[/url]
Posted : 26/09/2009 11:15 am
Easy vs £19........
Sounds like easy and then grumble about the cost 😕
Posted : 26/09/2009 11:38 am
