Thudbuster post ser...
[Closed] Thudbuster post servicing.
[#6392976]
The pivots in mine are pretty loose and squeaking.
Is it a send away job or can you get a service kit and ball park costs of both if poss?
Thanks.
Posted : 07/08/2014 2:03 pm
Not sure that the bushings are serviceable. Be interested to see if the are.
Posted : 07/08/2014 2:05 pm
I'd assumed that they would be softer than the post body so they could be replaced, but how do you spell assume....... 🙂
Posted : 07/08/2014 2:08 pm
They are. By the power of Google:
[url= http://www.bike-discount.de/en/buy/cane-creek-thudbuster-st-rebuild-kit-incl.-tool-58421 ]Rebuild kit[/url]
I've not done it, but looking at the included tool, I'd expect it to be easy...
Posted : 07/08/2014 2:09 pm
Most excellent
Posted : 07/08/2014 2:11 pm
I've just noticed that link is for the ST, but the LT model is also listed (extra EU5).
Posted : 07/08/2014 2:12 pm
i had the opposite issue with mine - it wasnt busting many thuds. i pushed out the pins, cleaned up the bushings and pins, covering everything in greae and reassembled. it busts thuds again now
Posted : 07/08/2014 2:15 pm
Will look at the link ta.
pj, take it u didn't have play in yours and it was just 'seized' a tad?
EDIT - I was going to try google but wanted some feedback too 😳
Posted : 07/08/2014 2:32 pm
Just found this link for info.
[url= http://www.thudbuster.com/instructions.html ]INFO[/url]
Posted : 07/08/2014 2:38 pm
PJ did you use the proper tool or sockets to push the bushings etc out?
Posted : 07/08/2014 4:50 pm
I dismantled mine for a clean, before reading the instructions, and managed to loose one of the brass washers. So if anyone has a brass washer they can spare i'd be very very grateful??
Posted : 07/08/2014 5:57 pm
Fitted new bushings and pins on mine using the kit from SJS.
http://www.sjscycles.co.uk/cane-creek-cane-creek-rebuild-kit-and-tools-for-lt-thudbuster-prod22751/
Dead easy and quick to do.
Posted : 07/08/2014 8:26 pm
As said kits are available , just be aware that the original thudbuster , not the ST or LT versions is not rebuildable .
Posted : 07/08/2014 9:22 pm
