The easiest tubeles...
[Closed] The easiest tubeless (& most robust) rim?
 hora
[#4546967]
Sick of constant pinchflats on my worn out EX500 rim. So.....recommendations for a strong yet sooo simple to set up tubeless rim?
Posted : 11/11/2012 3:36 pm
Most robust- Mavic 823. Ridiculous overkill for practically everyone.
Sane option- Stans Arch Ex or Flow Ex. Flow Ex is designed as a downhill rim, but light enough to be a trailbike rim. My Flows are the older model but still strong enough to win downhill worldcups (or for me to use them on the dh bike and ride like a knobber)
Some people talk about the "faff" of Stans rims. I always reckon these are people that either haven't used them, or who would have trouble operating sellotape...
That really is the only difference to Mavic- Stans needs a wrap of sticky tape applied first, after that they're functionally identical when it comes to inflating etc. My Flows are easier to inflate a tyre on than my 819s but the difference is trivial.
Mavic make great tubeless rims but only for the wheelsets- for aftermarket, the 819 is an ancient design and really shows it.
Posted : 11/11/2012 3:42 pm
Not tried the flow ex but if it's anything like the flow, it would be my choice. I run flow rims on both mountain bikes and arch on the road bike.
I like mavic rims, always have, but they just done seem to get the balance of weight and width.
Posted : 11/11/2012 3:45 pm
Can't complain about my Fulcrum red metals tough and easy to mount my Conti MK ll
Posted : 11/11/2012 3:54 pm
What size? 142 x 12mm any good??
Posted : 11/11/2012 3:59 pm
I did this a couple of years ago and ended up with Maxxis UST on mavic 823. Overkill, possibly, heavy, a little. Going to break? Unlikely.
Fashion police alerts, plenty but then I've never really been a dedicated follower.
Ps, I'm north of 17 stone with biking gear on.
Posted : 11/11/2012 4:07 pm
I have a pair of 823 wheels for sale if you are interested and a pair of flow 32 hole rims in white which I am looking to build into a hope hub set?
Let me know if you interested.
Richard
Posted : 11/11/2012 5:03 pm
 Ewan
Flow Ex = full name of the flow. There aren't two versions.
Posted : 11/11/2012 5:08 pm
I have a pair of dt swiss 5.1 rims which I think are the older version of the ex500, I have a dt swiss tubeless rim kit in them and the are by far the easiest re I have made go tubeless!
Done maxxis, schwalbe and even a none tubeless ready panaracer tyre with just some stans fluid and a track pump. I couldn't believe how easy it was! Would be cheaper and less hassle than new rims as well.
Posted : 11/11/2012 5:12 pm
Ewan - Member
Yes there are. Flow EX are wider and shallower than Flow. Flow are now discontinued, but you can find them in stock if you go looking.
http://www.notubes.com/ZTR-Rims-C18.aspx
this page gives you the different dimensions if you scroll down.
Posted : 11/11/2012 5:26 pm
Ewan - Member
Nope. Flow old model, flow Ex new model.
Posted : 11/11/2012 5:27 pm
