Ten speed 11-46 ?
[Closed] Ten speed 11-46 ?
[#10250215]
ive got a 46 tooth sunrace cassette and a goat link xt medium cage rear mech. Does anyone know if this should work ? The gear shifting seems all over the place at the moment. My only other option is a long cage xt mech which the goat link won't fit! I wish I'd never started this job now as I'm meant to be riding the bike in the morning!
Posted : 29/09/2018 9:16 pm
Should be a relatively easy check to see if it should have the mechanical reach to work or not.
If it does, then your set-up needs tweaking - bent hanger, old tight cables, knackered rear mech/ shifter / chain etc.
I use a 10-46 10sp Sunrace with SLX medium cage and no fancy link things.
Posted : 29/09/2018 9:36 pm
It should work but ime it is shit with clunky heavy shifting. (I ran this set up till last week when I smashed it off a rock cutting a line tight)
Fitted An 11 speed long cage xt mech works perfectly(even on the 10 speed system) and gives nice light shifting even with clutch on. And I didn't change cable inner or outer.
Posted : 29/09/2018 9:39 pm
How do I check if it had the mechanical reach ? New cables, new chain, new cassette, cant see that the rear hanger is bent as it's part of the drop out it looks pretty solid and straight
Posted : 29/09/2018 9:42 pm
Pretty sure the goatlink description says it only works officially up to 42T, but it seems to work fine with plenty of 46T. I used a 40T Sunrace with Slx non clutch mid cage mech but had to use a goatlink on the 46T version.  You will have to play around with the B screw adjustment to get the mech cage clearance on the 46T ring. Sunrace provide a longer screw but not always required.
Posted : 30/09/2018 12:36 am
I'm running the same cassette with a pilo (goat) link, on a zee mech with one up cage, shifting is ok but way too heavy with the clutch on so leave it off. Is your chain the right length.
Posted : 30/09/2018 8:44 am
My experience too Jim plops.
The 11 speed works perfectly even with clutch on . It's a revelation .without spending big bucks on a full 11speed set up
Posted : 30/09/2018 8:45 am
For a long time on my hardtail I've been running the 11spd version with a 10spd slx mech (rad-caged modded), obviously with a 11spd slx shifter with no problems. I can't see any reasons why yours shouldn't work.
As others have said, check the hanger, cables etc.
Posted : 30/09/2018 11:57 am
Slight thread hijack, I've bought a new frame and am looking at putting a 1x11 groupset on it with a 32t front and 46t rear, can you use a medium cage or would it have to be a long cage.
Posted : 30/09/2018 1:02 pm
That's a 35 tooth difference so it depends on the mech. For Shimano probably long cage, for SRAM medium should be ok.
Posted : 30/09/2018 2:42 pm
You can get ripoff goatlinks on ebay for £2. They work excellently.
Posted : 30/09/2018 3:02 pm
