Technique for ridin...
[Closed] Technique for riding over single logs
[#2942380]
Do most of my riding on rooty singletrack on a hardtail. Getting a lot faster but can't carry much speed over logs crossing the track. Nothing huge, probably about 6-10 inches. I normally pull the front wheel up and then use my clips to hop the rear wheel over. It works but isn't the most graceful.
Any hints, tips, techniques?
Posted : 13/07/2011 8:44 pm
How far off the ground, how much of a run up, what's the entry / exit like? All depends really, not one technique will work all round.
Posted : 13/07/2011 8:46 pm
Just hop it?
BMX, but same idea.
Posted : 13/07/2011 8:53 pm
 jedi
to begin with unweight the front wheel to touch the top of the log. then push it away again and bring the knees up to unweight the rear
Posted : 13/07/2011 9:06 pm
Lucien - varies. Normally on the ground. Sometimes I have five metres of run up an exit, sometimes they're on a corner. Normally on fairly flat ground.
Posted : 13/07/2011 9:14 pm
Thanks Jedi, will give that a go.
Posted : 13/07/2011 9:15 pm
I know people who purposefully clip the log with their front wheel to give it extra lift, whilst going for the hop, so it ends up kinda like a bunny hop. I don't do this!
Learning how the bike handles a chainring/log interface helps a lot. My SS has no bashring so I have to be a bit careful not to smash the chain into logs.
Posted : 13/07/2011 9:22 pm
Start small. Keep your bars straight. Generally speaking, if you can get the front wheel over the back will follow. A little bit of speed will keep the momentum going. Hesitation and doubt WILL uck it up.
Posted : 13/07/2011 9:53 pm
