Taper Headsets For ...
[Closed] Taper Headsets For Traditional Steerers.
[#5742808]
I'm just about to get a frame with a tapered headtube and I want to fit my non-tapered fork. I know hope to a product, but are any of you using other products? ~What do you guys reccommend?
Cheers.
Posted : 03/12/2013 11:06 am
Superstar and on-one do a similar thing.
Having used the on-one version I'd go for the hope pick and mix option every time (and I have Hope on two bikes currently).
What you getting?
Posted : 03/12/2013 11:08 am
The Superstar ones are good if you pack the bearings with grease before you fit,
Posted : 03/12/2013 11:21 am
Chris King also. You just need a bigger "baseplate" (that's CK for Crown Race)
Posted : 03/12/2013 11:33 am
Cane Creek do mix & match separates for top & bottom of head tube.
Posted : 03/12/2013 11:35 am
use a works components slackset on my scandal and it works a treat. Have a hope headset on my FS and that has a special crown race to allow straight steerers.
All work as they should really...
Posted : 03/12/2013 11:36 am
Pretty much all the major headset manufactures have an option for you.
I've used a superstar and Cane Creek headset. Both worked fine for me. Cane Creek cost a little more and looks like it is better quality. Haven't had either headset for more than 6 months so can't comment on durability but both are still spinning fine.
Posted : 03/12/2013 11:50 am
