Talk to me about th...
[Closed] Talk to me about the new revs
[#306871]
so theyre now bolt-through maxle, 140mm and weigh 1.7kg and seem like a nice choice and cheaper than a 15mm bolt-through talas. what i would like to know (and can't see from searching google)is:
1) are they all air forks or is there a coil version?
2) is it basically a pike on a diet?
3) will it be plush as a talas? (linear air spring)
there isn't that much around in the way of reviews at the moment
Posted : 15/02/2009 12:22 pm
1 - all air, pike are coil
2 - yep
3 - 🙄 maybe maybe not
Posted : 15/02/2009 12:26 pm
so air pike users out there, do you notice a ramp-up at the end of your travel?
Posted : 15/02/2009 12:34 pm
Be awre that they're not ALL 20mm axle as standard: they're still available with QR lowers, with the 20mms being a touch more expensive. Make sure you don't get the prices/specs mixed-up as I did...
Posted : 15/02/2009 12:41 pm
yeah i know they do a qr version
Posted : 15/02/2009 12:45 pm
so if the rev is the same as an air pike then whats the air pike like?
Posted : 15/02/2009 3:49 pm
They dont do an air pike anymore, just a coil one.
Posted : 15/02/2009 4:26 pm
youre missing the point
Posted : 15/02/2009 4:36 pm
They are not the same as an air pike. Less weight seems to equal less stiff in this case. Even around the Surrey Hills I could tell they were less stiff.
Posted : 15/02/2009 6:23 pm
cheers heihei i guess the only way to get a bombproof fork is to man up and take the extra weight. pikes seem well respected
Posted : 15/02/2009 10:05 pm
I've got the new maxle Rev. It's difficult to judge performance after one ride - and I can't compare it to an air Pike because I've never ridden one - but I wouldn't really say it was a flexy fork in any way.
First impressions are that it's like a QR Rev (oddly) but much better tracking. Noticeably less deflection at speed and makes it much easier to place the front wheel on slow technical bits.
Posted : 15/02/2009 10:25 pm
all i want to know is this: is it plush? (and does the rebound work)
Posted : 15/02/2009 10:33 pm
 mij
great fork, had one since Nov. Plush, stiff. Rebound works.
Posted : 15/02/2009 11:05 pm
cheers
Posted : 16/02/2009 12:57 pm
