Tacx flux thread
[Closed] Tacx flux thread
[#8249344]
I noticed on a few of the training threads flux's were mentioned.
I thought this may be useful for issues, comparing notes, etc etc.
I'll start with mine....I can't see how to start and record a work out on the app (on S7 and iPad air) which is rather frustrating.
Otherwise the apps aren't particularly inspiring...!
It seems to be connected, on o e device it calibrates, the other I assume isn't picking up a signal as the start pedalling screen doesn't disappear.
I'm hoping Trainerroad will resolve these issues for me....!
Posted : 31/12/2016 3:08 pm
GUESSING:
bluetooth pairing in 1:1 and I thinkl ipads are all BT so if your ipad is paired then your phone won't - and vice versa
I have no idea whether the trainer will run BT and ANT at once
(I don't have one, so can't check either)
Posted : 31/12/2016 3:12 pm
I'm really interested to hear how they perform. I'm trying with the idea of buying one over a normal wheel on turbo
Posted : 31/12/2016 7:33 pm
/\ ditto.
As for apps, was going to us zwift, as seems to be the most engaging
Posted : 31/12/2016 7:49 pm
I struggle to calibrate mine, always says too loose. Are you supposed to warm it up first?
Posted : 31/12/2016 7:52 pm
tricky - I think maybe you have a flow rather than a flux
I don't have one of those either but if it's too hard to tighten, maybe you could let the tyre down a bit, tighten the roller and then pump up ?
(baggsy not responsible if something snaps though !)
Posted : 31/12/2016 8:09 pm
My bad, you're right I have a flow! Wrong thread, although would enjoy a flux if I could justify the cost
Posted : 31/12/2016 8:19 pm
Scaredypants, I was trying them separately with the app only open on one. It looks it should've bless to do one of each however...
Tom I thought TR might be a little more structured, I imagine I will change between the 2 every few months.
And for tricky, the cyclescheme helps justify the cost...!
Posted : 31/12/2016 9:56 pm
