stumpjumper and rev...
[Closed] stumpjumper and reverb
[#6053331]
I want to get a dropper post for my 06 Stumpjumper (the one with the interrupted seat tube, wrapping around the rear shock). The short seat tube is open ended so can I use a stealth reverb or will the shock be in the way of the remote hose? Also can you use a right hand remote lever under the bars on the left and still use a xt shifter fitted with a hope x2 on a matchmaker?
Would a normal reverb and a standard left hand lever be a better option?
Posted : 20/03/2014 10:44 pm
If its anything like Katies 06 Enduro the stealth will foul the shock. We fitted a Specialized Command post to hers but had to go for the 100mm travel as the 125mm one was too long
Posted : 20/03/2014 10:49 pm
Tracy I think they are similar in frame design. I can just get a 370 seat post in (the one I use at present his be cut down) I did think the shock position may be an issue
Posted : 20/03/2014 10:54 pm
Will the remote fit under the bars with a left hand shifter?
Posted : 21/03/2014 5:29 pm
