Stroker Trail servi...
[Closed] Stroker Trail servicing
[#594979]
My Strokers are getting pretty sticky- the brakes are effectively always on at the moment and the pistons seem to creep out even after being pushed back in. What's involved in taking them apart- will I soon be wishing I'd just taken them to a shop?
Posted : 01/06/2009 10:46 am
Try bleeding them first before taking them apart. Bleed kits are £15.
Posted : 01/06/2009 11:16 am
Caliper comes apart pretty easy (I had to replace a piston recently), I'm now having problems getting them bled properly though :p As for sticky pistons you may get away with cleaning the pistons and lubing them with a bit of dot fluid.
Posted : 01/06/2009 11:36 am
I'm not sure they [i]are[/i] sticky I suppose- I assumed they were reluctant to go back in because of crap behind them (which there probably is anyway) but I guess bleeding is probably the place to start.
Posted : 01/06/2009 11:38 am
There is a guy in CRC's workshop who is apparently a demi-god at fettling these.
Posted : 01/06/2009 11:39 am
Try some silicon spray lube like Stendec Superglide down the side of the pistons, and then work them some. Clean off thoroughly afterwards!
If the lever is not returning then try the same with the master cylinder.
Posted : 01/06/2009 11:48 am
Teh guy at CRC should be a demi god at serviceing hayes brakes as hotlines is owned by CRC and they are the distributors....
Sounds like he has had lots of practice at repairing them!
Posted : 01/06/2009 1:44 pm
