Does anyone know if I can find my old KOM's? I've had a look but without going through every previous ride I can't find them.
Also has anyone else had a section declared hazardous? One on a ride I do has and its uphill!
Someone's flagged False Teeth at Coed-Y-Brenin on the MRB trail! There's nothing dangerous about it, other than that if you're really going for it you can land in the bottom, just before the next jump but if you're going that fast then you should be able to squash jumps ffs! The only other thing is a couple of drops but they're nothing mental. 🙄
I'm pretty pissed off about it tbh, because I reckon I'd be in the top 10, considering I'm 9th/430 for False Teeth 2. 👿
If there is nothing wrong with the segment, then just email support and they will un-flag it or, just remake the segment yourself.
KOM's are on your profile page I think, its the one you get when you click on your name.
you might be able to get something out of
http://www.jonathanokeeffe.com/strava/notifier.php
or one of the links at the bottom of the page. It gives histories for segments but then you'd need to know which segments you held a KOM on.
I've reported a segement as dangerous. The millenium bridge in Newcastle. Cycle lane is about 6 feet wide, shared use and often busy.
shotsaway, I waked past a Strada over the weekend and had a little chuckle....
