"Sticky" ...
[Closed] "Sticky" ultegra sti - wassup ?
[#4339765]
RH rear - happened after cleaning the bike (or rather spraying it with diluted muc-off and rinsing)
Next time on the bike (few days) and the rear shifting felt amost jammed
I wondered if I'd trapped a cable or something at first
Cable & outer sections all run free
Mech, "no" resistance when moved by hand
It's the "pull" aspect that's not right - it'll release absolutely fine but the big lever seems to have become sticky and as though the cable isn't properly adjusted (doesn't shift a gear until the 2nd click) but this happens at any point through the gears rather than at one extreme including immediaely after using the little lever
Is this what they do when they're dying ? 🙁
Currently on intensive GT85 therapy and has improved a bit but still feels wrong
Posted : 07/09/2012 11:42 am
Keep attacking with GT85 and attempt to get it moving without excessive force.
Hopefully it will loosen up. Once it does, get it onto some thicker chain lube and repeat the process.
Posted : 07/09/2012 12:03 pm
My money is on the cables/outers. They can feel fine but still cause this sort of issue.
Posted : 07/09/2012 12:07 pm
cable & outers have been "released" from the frame and all outers slide completely smoothly along the inner. I can't believe it's that.
GT85 - yeh; and I smell gorgeous !!
Posted : 07/09/2012 12:09 pm
GT85 = Perfume for REAL men (not classifieds scammers though)
Posted : 07/09/2012 12:13 pm
no fraying on the cable or other issue? What you are saying does not add up.
Posted : 07/09/2012 12:20 pm
Oh check the cabe's not frayed/jammed in the shifter.
Posted : 07/09/2012 12:23 pm
The really weird thing is the fact that it's when pulling cable that it doesn't work right - the spring in the mech is perfectly able to pull released cable back down the whole run but it's stiff when pulling ( 😉 )
Have removed it all (no fraying at all) and going to flush everything/lube the crap out of the sti and see what happens
Posted : 07/09/2012 12:31 pm
UPDATE - so nobody loses any sleep tonight
took off, sprayed the sti out with lots of GT85. SPrayed out all cable outers too, and cleaned the wire. Sprayed the mech until it drowned.
Now works with the old light feel. No idea which bit worked.
I'll get greased/oiled up and back into action later
Err, edit: Sorry, I meant the gears; no pics of me to follow 😉
Posted : 07/09/2012 4:39 pm
