Stem spacers.
[Closed] Stem spacers.
[#4256378]
How many of you permanently run spacers ABOVE your stem? Why?
Pics would be cool.
slainte ❓ rob
Posted : 13/08/2012 10:27 pm
It's meant to be safer, as it gives more steerer for the stem to clamp too, so I think makes it less likely for the stem to slip, or the steerer to fail.
However it's not really worth too much thought, unless perhaps you're running a super light carbon steerer on a bike that takes quite a bit of abuse. I've got some spacers above some of my stems, but mostly out of laziness.
Looks so much more boss without spacers though.
Posted : 13/08/2012 10:32 pm
I use one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=34720 ]these[/url] (the smaler one), as I wanted to keep a little length on the steerer for a future frame.
I do as I don't really see the point of cutting the steerer tube as it looks fine.
Have a Cateye Micro mounted on the stem and the slightly raised spacers stop it getting knocked off the mount.
Posted : 13/08/2012 10:34 pm
I have 10mm ontop of a sunline xc-one stem. The stem has a very low stack height and the frame has a small head tube so i'd rather not cut down the fork steerer in case i change the stem or frame before the forks.
i've got 10mm as I don't want to cut my steerer any shorter but have the bars right where I want them.
5mm looks okay, 10mm looks a bit daft but the set up being right is more important than looks.
Posted : 13/08/2012 10:38 pm
I think I have about 30mm of spacers above. I guess it's fractionally heavier but it means I haven't had to cut down the steerer which has saved some effort and means the forks will fit more frames in the future.
Posted : 13/08/2012 11:01 pm
chiefgrooveguru +1.
I,m sure i,ll change the frame before the forks so why cut down the steerer.If i do cut it sods law says they won,t fit the new frame. 🙁
Posted : 13/08/2012 11:06 pm
