Just wondering if anyone can recommend a steerer expander which will fit a carbon fork with a 20mm internal diameter?
The Lifeline one looks great and is very cheap at something like £7 but it's for 22-25.4 or so it says - anything else around?
1" steerer?
Deda used to make a ~20mm Spadca (they also make a version for 1 1/8 so check this)
timba - Member
1" steerer?
Just a very thick tapered steerer tube - it's a BMX so could have a few forces put through it. I've measured the inner at 20-20.5mm give or take so the Spadca would be great but haven't seen one on line yet.
Did anyone ever make 1" steerer? I thought the aheadset standard started at 1-1/8"!
G
[url= http://shop.kinetic-two.co.uk/advanced-kinetic-one-elite-race-carbon-forks---1-inch-steerer-31-p.asp ]Yep, early 1990s? Some on ebay too...[/url]
[url= http://www.ribblecycles.co.uk/csn-carbon-alu-road-forks/ ]...maybe a stockist will have a bung?[/url]
You could get full CF monocoque fork with 1" steerer back then from a few manufacturers, they seem to be a bit thin on the ground now, hopefully a few bungs exist still
