Steel frame welding
[Closed] Steel frame welding
[#876446]
[img] http://newimages.fotopic.net/?iid=1ybs1h&outx=650&quality=70 [/img]
Hope the pic works, they don't usually.
Frame on my commuter cracked and fell in bits so I had a mate weld it, apparently its hard to weld over brazing. Not the prettiest welding I’ve seen but it seems to work ok.
Posted : 17/09/2009 9:49 pm
So why does the image appear for a few seconds and vanish?
Posted : 17/09/2009 9:56 pm
upload it on tinypic.com and paste the [ img ] link into your post
Bollox - not bothered enough to mess with it.
Posted : 17/09/2009 9:58 pm
here you go.
Nice!
Posted : 17/09/2009 10:02 pm
did a seagull land on it?
Posted : 17/09/2009 10:04 pm
Peregrine - I had the same thing happen with an image i tried to post a couple of days ago (stealth bikes). Were you using fotopic as well? Are they trying to stopped hotlinking or something?
(oh, and that's great welding!)
Posted : 17/09/2009 10:08 pm
Is your mate Stevie Wonder?
Posted : 17/09/2009 10:30 pm
Could you have found any bigger cable ties to secure that computer wire?
I also suspect your "mate" might want you dead.
Posted : 17/09/2009 11:16 pm
Gas weld?
Posted : 17/09/2009 11:56 pm
i think the cable tie may be a load bearing structural component
Posted : 18/09/2009 12:09 am
that's asking for trouble. shit welding that's contaminated with brazing filler.
a gusset where it shouldn't be (concentrating stress in one place instead of around the tube)
steel tubes are thin which makes them tricky to weld, looks like a load of birdshit mig or stick work which is not used to weld bike frames.
it will probably be fine 🙂
i wouldn't want to ride it though.
Posted : 18/09/2009 12:12 am
yer sh*t welding puting heat affected zones round stress point not a good idea, i wouldn't ride it
Posted : 18/09/2009 6:44 am
good luck.
Odd that that's a high quality fork crown but the frame doesn't look great...and it's a cheap crap headset.
Posted : 18/09/2009 6:57 am
 Zone
Impressive! I've never seen welding from someone who is blind before.
Which part did his dog do? 🙄
Posted : 18/09/2009 7:00 am
