Stans No Tubes?
[Closed] Stans No Tubes?
[#787927]
After having to fix several punctures today in the pouring rain I'm thinking of going tubeless.
Looking at using the Stans No Tubes solution on my existing Mavic XM321 and Panaracer Cinder tires.
Does anyone have any experience/opinions/Pros Cons on the No Tubes solution?
Posted : 15/08/2009 6:00 pm
Went tubeless myself about 18 months ago using stans kits with dt 4.2 & 5.1 rims with panaracers , bonty mud x and specialized non ust tyres, it has been a really positive experience, the only real issue was inflating the tyres initially, but once you have the knack thats fine too. Suggest a compressor or co2 cartridges to take the pain out of that and a sringe from stans for adding more sealant. If you do a search on here you will see a wide variety of opinion though so I suggest only real way of telling if its for you is to give it ago.
Posted : 15/08/2009 6:11 pm
 gee
It's brilliant.
GB
Posted : 15/08/2009 6:28 pm
I had a few teething problems with Panaracers. Took a while to get them fitted because the tyres are very porous. You have to make sure [i]every[/i] square mm of the inside of the tyres is coated with the solution, otherwise they will deflate. I would suggest a bit more solution than recommended in, and do the shake shake as explained on Stan's videos, do it for as long as you can be bothered or until you're sure it's all coated!!
I definitely needed a compressor the first time, the (wire bead) Pana tires wouldn't sit right on the rimstrip so it needed that powerful blast for the initial inflation. However, I have managed to reinflate them using a trackpump after topping up the fluid (after ~6 months use).
6 months without a flat is pretty 8)
Posted : 15/08/2009 7:01 pm
Unless youre fat and corner hard, you will love it.
Posted : 15/08/2009 7:06 pm
Converted 6 moths ago and never had a problem. Initial inflation (track pump) was the only faffy bit
Posted : 15/08/2009 7:07 pm
How offten do you need to top up the sealant?
What is the routine if you do get a flat on the trail?
Old style inner tube?
Posted : 15/08/2009 7:26 pm
Have a look at doing it 'ghetto' - Much cheaper & just as effective
Pana Cinders aren't the best choice of tyres mind
Have a look here for recommend brands
http://www.justridingalong.com/content.php?pid=529
It's not gospel but gives you an idea
Posted : 15/08/2009 7:34 pm
Top up the sealant when its running low (shake tyre, if you cant hear it sloshing around, its running low)
Say once every 3-6 months maybe?
Well, you dont. But if you get a massive tear it cant seal, then yes, you just stick a tube in, try to patch the hole, and off you go.
Posted : 15/08/2009 7:45 pm
Well in all my tears of riding i can't recall ever having a massive tear in my tires so all looks good.
Bad news on the panaracers though, wasn't wanting to change my tires as they are fairly new.
Anyone else experience of using Panaracers with this?
Posted : 15/08/2009 8:08 pm
 gee
Fit tape (to seal the spoke holes and in case you ever have to whack a tube in)
Fit rimstrip - use screwdriver underneath to seat evenly
Fit tyre
Remove valve core
Squirt in 100ml sealant
Replace valve core
Do tubeless dance
Hold wheel in air, put valve at top, pull (pinch apart) the sidewalls either side of the valve to ensure a good seal in this area
Pump like a loon/use compressor/use C02
Do tubeless dance to find small pin-size porous holes in tyre sidewalls, particularly where the sidewall joins the tread and bead.
Be prepared to repeat the last step, even to add more sealant, over the first 2 weeks of having the tyre on.
If you get a flat, let the spooge deal with it by rotating the tyre so the hole is at the bottom. If it can't cope, remove tyre and rimstrip and whack a tube in.
GB
Posted : 15/08/2009 9:16 pm
i had to trim the rimstrip slightly too, but all works fine.
Posted : 07/09/2009 3:40 pm
shit.... i'm a big fat b*stard, who corners real hard, and was just about to go 'tubeless'
what's the deal then?
4.2's and minions both end's.
Posted : 07/09/2009 3:59 pm
err... that should have been 5.1 rims, and minions
Posted : 07/09/2009 4:09 pm
I've got Stans to work with the Cinders in the past - don't think it was that difficult. However, I would definitely go ghetto as the cost of the stans kit seems to have gone through the roof recently.
Posted : 07/09/2009 4:21 pm
if it splits make sure you have some anchovies to repair, depending on where you ride if your tyre has thorns in the tube will pucture pretty much straight away
Posted : 07/09/2009 9:53 pm
Heard that you can put enough sideways force to tear the tyre away from the rim, which means you almost immediately lose all air and sealant, and end up in a big mess on the floor covered in sealant and a tyre hanging off a rim.
Posted : 07/09/2009 10:04 pm
I'm fat and corner reasonably hard - never had a problem with the ghetto system with 719s.
Stan's rim strips seem to be a massive rip off compared to a 20" BMX tube.
Posted : 07/09/2009 11:00 pm
Only recently I could have had one of the stans kits for £25 Brand new, It was at a trail centre in a battered box in the bargain bin 🙄 Should have grabbed it thinking back now
Posted : 07/09/2009 11:08 pm
Just done mine for first time tonight.
355 rims and fitted XC pro's.
3oz of fluid instead of the recomended 2oz.
Quite a few white spots on the sidewalls, but they soon seemed to be o/k.
Tomorrow will see if they are still up, then its fit rotors and try.
Posted : 07/09/2009 11:10 pm
i no tubed an ancient x139 last night and its held pressure all night...happy with that!!!
it would help for you to watch [url= http://www.notubes.com/support_movies.php ]this[/url] before you install it for just a few little tips which make it easier.
Posted : 08/09/2009 7:28 am
scrub round that, after 4miles out with a group i've never been with, the tire suddenly lost pressure and i ended up skipping the rest of the ride whilst i sorted out the big mess that was sticking a tube back in.
rubbish
Posted : 08/09/2009 8:47 pm
