Stans MTB rims and ...
[Closed] Stans MTB rims and 23c tyres
[#5817251]
Planning on using tubes - anyone out there doing this and will they pop at 100psi, or am I just being silly?
Yours suspecting there's only one way to find out
Paul
Posted : 02/01/2014 5:45 pm
Have a look at Sheldon Brown and Schwalbe. There's a table out there that shows tire size against rim width. I run Stan Arch rims on my cross/commuter. It's a 19mm internal rim. The narrowest tyre I can run is 28mm.
What rims are you running?
Posted : 02/01/2014 5:51 pm
Hi Onzadog - many thanks for the note - I'm running the Olympics - all I'm seeking to understand is whether or not I need to strip my existing road wheels to reuse the CXP rims OR - just flog them on and use the MTB bits n pieces I've got lying about. i'm also after a 36 hole disc hub - if you know of such a thing lying about.....
Paul
Posted : 03/01/2014 6:48 pm
The Olympics are too narrow for 23mm tyres. As for the disc hub, pretty sure Hope will have something.
Posted : 03/01/2014 7:34 pm
 gee
I think you mean the Olympics are too wide to run a 23c tyre?
I think anything narrower than a 30 will be pushing it.
GB
Posted : 03/01/2014 7:39 pm
I've managed to run Conti Grand Prix 26" 1 1/8 tyres on my Stans Crest rims with no problems.
Posted : 03/01/2014 7:47 pm
Why 23mm tyres?
http://inrng.com/2013/04/reinventing-the-wheel-25mm/
Posted : 03/01/2014 8:22 pm
The other thing to bear in mind is that a lot of MTB rims aren't designed to run at high pressures. Magic and DT certainly have upper pressure limits on some of their rims. I've seen a couple of MTB rims split when run at high pressures.
My 717's are fine with Schwalbe durano's at 110 psi.
Posted : 03/01/2014 8:30 pm
Gee, you're right. Well spotted.
Posted : 03/01/2014 8:55 pm
I've b been using 25mm tyres on 29er Crests for ages. Stans confirmed that the pressure limits on the rim only apply to tubeless setups.
They're a tight fit though, I'd also say why 23 and not 25/28?
Posted : 04/01/2014 12:02 pm
Crests 29er with 28mm Marathon plus here and up to 100 psi. No problems but sods to get on and off!
Posted : 04/01/2014 12:11 pm
I've run 23c tyres on my Ztr Arch no probs,
They are only 1.4mm wider than the rims on my road bike.
(I used 23c because its what I had, having a choice I'd go bigger)
Posted : 04/01/2014 12:12 pm
Sheldons advice on this one appears a bit out.
Posted : 04/01/2014 12:14 pm
http://www.hutchinsontires.com/en/mtb/82-stick-air.html
Posted : 04/01/2014 12:18 pm
I tried 28mm Contis on Mavic A119s and got loads of flats. Went back to 35s and no problem.
You might get lucky, but I would doubt it.
If you have some lying around why not just give it a go?
Posted : 04/01/2014 12:43 pm
