Stans Flow EX or Ma...
[Closed] Stans Flow EX or Mavic EN521?
[#6342449]
Hi,
I'm currently running EN521's but fancy a new wheel set and I'm thinking of a change and trying Stans, are the Flow EX just as strong as the EN521's?
Any good or bad comments would be good before I pull the trigger!
Posted : 15/07/2014 7:29 pm
Can't comment on the mavic's mate , but the flows are great. I've smashed mine down some really rocky trails in the lakes and they stand up well.
Posted : 15/07/2014 8:07 pm
Have got some 521s on 20 mm XT from 2011 they're still straight and true. Sometimes think about changing them but I know I won't
Posted : 15/07/2014 8:15 pm
My 521's have been spot on too.
Hmmmm, might give them a go!
Posted : 15/07/2014 8:20 pm
I can't compare with 521s but with pretty similiar capability 721s (the posher and theoretically stronger model). Broken 'em both for a fair comparison 🙂
They're pretty similiar tbh. But the Mavics are harder- harder to dent etc. Stans rims tend to be a little soft, which means they pick up dings more easily (and straighten more easily, to balance it out a bit). I've put a big dent right into the bed of my rear flow ex, I'd be fairly confident that the 721s wouldn't have been as bad.
But, hardness doesn't equal strength- ie durability. Both cracked after a decent lifespan, both did time in a trailbike and a downhill bike. None got ridden especially [i]well[/i]but then clumsy riding is probably a good test too 😆 The Mavics cracked in a number of places at the spoke eyelets, which was a wee bit irritating since everyone says the eyelets should make them stronger- in practice it seems to create a stress point.
One of the Flows cracked at the valve hole, the other is still in use but is no longer very round so I think it'd be fair to call it dead- it's just dented to the point it doesn't really qualify as a functioning wheel. I don't object, but I reckon the Mavics would have stood up better to that.
So 3 out of the 4 knackered wheels it just came about through use and long term wear and tear. The 4th was a single blunt instrument caused by riding like a cock at fort william. I think on balance the Mavics are slightly more survivable... But then they're also heavier, and not tubeless ready. (but more expensive)
Both good really and I'd buy either again but I preferred the Flows. I think if you often ding rims (ie you like low pressures) then maybe the 521s come into their own.
Posted : 15/07/2014 8:40 pm
I'd echo what NW said.
My experience is that the 721 is a very tough rim which doesn't ding easily at all. For a tough, albeit not particularly light, rim it is my first suggestion. If you want something lighter though, then the FlowEX is more suitable. For these reasons, on the hardtail, I run a Flow EX on the front but a 721 on the rear.
Posted : 15/07/2014 8:51 pm
Cheers NW, I appreciate that.
I've had no issues with my current wheels, other than the standard hub service and tweak with a spoke key here or there.
One of my mates runs the standard flows and he's had no issues, plus he weighs more than me too!!
I like to think I'm not too heavy on wheels so by the sounds of it I should be ok with the Flows.
Posted : 15/07/2014 9:02 pm
The 721 is actually 50g heavier than the 521 - it's an "EX" rathrn than a "EN" too - Extreme? Enduro? - intended for harder use, I think.
And s different alloy to the 521 - Maxtal versus the 521's 6106.
That new 821 is probably a closer comparison to the Flow - still narrow though
Posted : 16/07/2014 11:31 am
Have you considered the new Hope Tech Enduro hoops?
I'm a 521 fanboi having used them for years, but recently stuck a full Hope on the front and all seems good so far
Posted : 16/07/2014 12:19 pm
I did consider Hope rims but read mixed reviews, how long have you had yours?
Posted : 16/07/2014 5:35 pm
Not sure what the USP of the Hope rims is - you can have a Hope Hoop with a Flow rim, or have one for the same price with a heavier Hope one.
Posted : 16/07/2014 5:41 pm
Flow EX
Hope Enduro
Mavic 521
I'd say the Hope looks like the sturdier build
Posted : 16/07/2014 7:54 pm
I've just ordered Flow EX so they better be as good as the EN521's they're replacing (now for sale on here ) 😆
Posted : 16/07/2014 9:26 pm
