Stanchion maintenan...
[Closed] Stanchion maintenance
[#2200094]
I've been through some old threads, and see that many people put 'fork juice' on stanchions after a wash. I suspect that 'fork juice' is not the technical name of the substance in question.
If it is not, then what exactly is it? Fork oil?
I don't have any fork oil under hand. Will silicon or teflon spray be acceptable? Extra virgin olive oil? Jersey butter?
Posted : 18/11/2010 11:48 am
Google fork juice 😉
Posted : 18/11/2010 11:49 am
I think silicon spray is all it is, also heard of people using a bit of wet lube instead
Posted : 18/11/2010 11:54 am
Well I'll be...
Didn't even occur to me that it could be a real thing.
Thanks jools, I'll stick to the silicon spray then.
Posted : 18/11/2010 11:58 am
I've always just carefully wiped mine with some clean kitchen rolls afterwards going UP and away from the seals.
Posted : 18/11/2010 12:00 pm
I use Teflon based lube - in my case Finish Line Dry. (I believe that's what TFT recommend too).
Drop it all around the wiper seal, cycle up and down a few times, wipe, repeat.
Posted : 18/11/2010 1:53 pm
