SS chain wear..
[Closed] SS chain wear..
[#1021930]
Chain stretches more on the ratio im using for round here at 32.16.seems to me every couple of rides stretches far too much.
If chain snaps do you carry a spare bit of chain and 8spd powerlink?
Posted : 08/11/2009 2:51 pm
Nope use a half link chain, reattach back together and slide in drop out to get correct tension
Posted : 08/11/2009 2:54 pm
If your new chains are wearing out quick, it sounds like worn sprockets causing it.
Posted : 08/11/2009 6:41 pm
or your wheel/tensioners moving .....
Posted : 08/11/2009 6:45 pm
 Smee
Sounds to me like your chainline might be away to hell.
Posted : 08/11/2009 6:46 pm
A singlespeed specific chain like a KMC 610HX might help, although even 8sp chains don't stretch that badly.
And yup, a spare bit of chain is a good idea.
Posted : 08/11/2009 6:54 pm
I don't mean to sound patronising, but are you sure your wheel isn't moving? Every ride or two seems impossible (or you have thighs like Chris Hoy)...
Posted : 08/11/2009 6:56 pm
the cure
http://www.evanscycles.com/products/shadow-conspiracy/interlock-v2-chain-ec011381?utm_source=froogle&utm_medium=froogle&utm_campaign=froogle
don't use a chain tool on it, you will break the tool
Posted : 08/11/2009 7:15 pm
do you drive a sherman tank to the nursary to pick up your wain ?
Posted : 08/11/2009 7:19 pm
 Del
it's not unusual for a new chain to 'grow' quite rapidly early on, but it should settle down, unless you're just using 5hit chain.
Posted : 08/11/2009 7:40 pm
The shadow chains stretch really badly.I ran them on my 20" for a while with simple slammers-chain tensioner that cannot slip,cos they physically fill the gap- and they stetch quite a lot from new before calming down.
Posted : 08/11/2009 7:47 pm
no, I ride SS up hills and I weigh more than the average rider 😉
the only chain have have not ditched due to stretching
I had a Shadow chain that grew so much that I took enough links out to make another chain. 😉
Posted : 08/11/2009 8:19 pm
