SRAM stealth-a-maji...
[Closed] SRAM stealth-a-majig and hose replacement
[#10095843]
Hi, I finally decided to re-route my brakes so that the hoses pass on the correct side of the headtube.. a bit OCD maybe but it has been irritating me for a year now!  Anyway I've already cocked it up as have realised that the rear hose is not long enough for this and is also the new stealth-a-majig type fitting.  So two questions:
It says I can not re-use the olive and barb.  Is this because the olive will have been compressed despite being the new design?  If so does that mean you can never disconnect then reconnect a brake lever without a new olive?  New olive/barb kit is a rip off 15 quid.  I have a load of standard avid olives but it sounds like I can't use these 🙁
I'm sadly going to need a new longer hose.  These seem to be £30 which include the caliper end connector.  Is there any way to do this on a budget using 3rd party hose and re-using the existing connector or is that impossible?
Had no idea this little aesthetic fix was going to take half a day and cost me £45 or I would never had bothered.. thats almost enough to bin the brake and buy shimano! The curse of an over keen fettler! 🙂
Posted : 16/07/2018 12:19 pm
Olives are not reusable as a rule, the inserts can generally be reused. The caliper connector is crimped and cannot be reused.
As a 3rd party alternative, there is the option of a Jagwire Pro hose and associated Quick-Fit adaptors - around £45 for both on ebay, but you get 2x the hose length and connectors, so effectively half price.
Posted : 16/07/2018 1:09 pm
Thanks for the info.  Looks like superstar have hose plus fittings for under £20 and enough for two brakes.  Unfortunately does not look like they have SRAM Guide fittings :/
Posted : 16/07/2018 1:19 pm
I have a fair few times. But only Shimano, I think.
Last time, I swapped levers from one bike to the other and neither needed new hardware. Or bleeding, for that matter.
Posted : 16/07/2018 3:52 pm
If you need a longer hose you're doing it wrong. The hose should pass on the same side of the headtube that the lever is on, which is the shortest possible route.
Posted : 16/07/2018 3:59 pm
Interesting, almost all bikes I see have all cables passing in front of the headtube.  The setup on my bike was a mixture of both types so looked a total mess.
Posted : 17/07/2018 1:45 pm
Only an absolute savage would do this.
If it's the red olive, I don't think you can re-use, the end gets crushed against the hose, so you won't be able to re-fit it. The threaded barb will be reusable. You can buy 5 for £15 though, so it's not too expensive.
Posted : 17/07/2018 1:53 pm
